I'm not 100% on the grade,
Can't be far off 75W90 bit don't take that for def.
Itl be about 2.5L so better to get 3L
Unless it had a factory or aftermarket LSD then it will be different oil
Hope this helps man
Gary
def 75w90, unless u have an aftermarket mechanical diff, then its different not sure what tho, helical is fine with 75w90 and bout 2.5l as mentioned
fill it from the top bolt on the top of the gbox and undo the nut on the front of the box too, when it runs out of the hole on the front, u have enough
