adee-ep Posted November 12, 2009 Posted November 12, 2009 ive done a 5efte swap and where the oil filter goes is slightly different. i have used my 4efte sump so i have that oil line fine. but see the little metal oil line that also connects onto the bottom of the turbo were does the other end of that go? it would normally go to the bit beside the oil filter on the 4efte but thats not there on the 5efe so what do i have to do? cheers Quote
Idrees Posted November 12, 2009 Posted November 12, 2009 Have you used the 4E oil filter housing block? If not, my guess would be to use that. Quote
StarletRick Posted November 12, 2009 Posted November 12, 2009 you need the 4e oil filter block that moves it to the left. the stock block doesnt have any taps for oil feed on it. Quote
adee-ep Posted November 12, 2009 Author Posted November 12, 2009 the housing doesnt fit on the 5e Quote
StarletRick Posted November 12, 2009 Posted November 12, 2009 it does, you just dont have the studs to mount it on. you can fit it though and it does stay in place with the centre nut. you just have to make sure its lined up properly. Quote
adee-ep Posted November 12, 2009 Author Posted November 12, 2009 it does, you just dont have the studs to mount it on. you can fit it though and it does stay in place with the centre nut. you just have to make sure its lined up properly.i see il get this done cheers Quote
