chr15_7_t_ Posted November 20, 2009 Posted November 20, 2009 what the best but not overly expensive? not including coilovers ..i meaning about anti roll bars Quote
chr15_7_t_ Posted November 20, 2009 Author Posted November 20, 2009 ooo has riko got a posable sale for me ? lol... Quote
riko666 Posted November 20, 2009 Posted November 20, 2009 I think you'll find on the forums that its generally accepted that a Rear anti-roll bar and the Anti-lift camber kit are the most cost-effective modifications that can be done, with the most pronounced improvements. A good set of shocks and springs will make a good difference, as will obviously good tyres. There's many more too! Contact me about the anti-roll bar (or bars) chap Quote
rorenapier Posted November 20, 2009 Posted November 20, 2009 Dont forget to add an Adjustable panhard rod if your car is being lowered. Quote
iamlegend Posted November 20, 2009 Posted November 20, 2009 Dont forget to add an Adjustable panhard rod if your car is being lowered.why is this?? does this have to be done thow ? Quote
ToyotaTech15 Posted November 20, 2009 Posted November 20, 2009 It's going below the correct set height by the factory so one side will sit higher at the back and the standard one can't be adjusted to correct it.Doesn't HAVE to be done but would recommend as they aren't that dearGary Quote
rorenapier Posted November 20, 2009 Posted November 20, 2009 If your lowering the car at any height, then an adjustable panhard rod is needed.If not the rear axle sits to one side, and the handling of the car is kek., regardless of all the mod con suspension you may have.If a jobs worth doing, its worth doing right. @Gary - Sit higher, you sure you dont mean sit to one side?? Quote
Steve GT Posted November 20, 2009 Posted November 20, 2009 best cheap handling mods are as been said, anti lift kit, adjustable panhard rod, rear anti-roll bar, shocks and springs etc, front and rear strut brace and bottom bracethen your looking at more expensive mods like coilovers, 6 point rear strut brace, roll cages etc etcsome say LSD will help handling some say its shite lol Quote
ToyotaTech15 Posted November 20, 2009 Posted November 20, 2009 Well from what I've seen people complain of one side sitting slightly higher than the other,Never experienced it much in my car to be honest,Didn't realist it sat to the side, cheers thou rory,Gary Quote
BAZ2CRAZY Posted November 20, 2009 Posted November 20, 2009 The fact the car is sitting higher than the other would partly be the chassis being ever so slightly different one side than the other and damper/spring wear etc. Not having an adjustable panhard rod will only make the axle sit to one side and not have an effect on the height (with in reason)As people have said above, anti lift kit and ARB's.My n/a is on kyb sr special shocks and rsr springs and the body roll is pretty gay. How ever my GT is on coilovers and theres pretty much 0 body roll, so i believe certain parts should be added in relation to how other parts effect the car/handling.For example in the new banzai, theres a silly fast road CRX. They actually removed the rear anti roll bar to prevent the rear end being wild/snappy under deceleration. Get what im saying?Mitch Quote
rorenapier Posted November 21, 2009 Posted November 21, 2009 No bother Gary.And another thing, replace old bushes!Adding ARB's, Anti lift kits etc will only mask any problems, if there are bushes worn out.All bushes can be bought, so i personally would be looking at them first, then adding the anti lift kit, and rear ARB.These setup with a good spring / shock combo will see nice gains in the handling dept.Then you can start going further with coilovers, Fr ARB's etc etc etc Quote
