heres my spec list to date
.5 rebore on each cylinder now at 74.5mm
74.5mm wiseco pistons
scat rods (block notched)
arp bolts
acl racing big end bearings
acl racing main bearings
1.2mm cruise headgasket
cruise valve springs
light polish to ports
exedy cerametallic paddle clutch
hks ssqv
hks mushroom induction kit
heat range 8 ngk iridium spark plugs
tongs gt spec ct9 hybrid
autobahn mani (learned from that mistake)
zisco ext gated mani
zisco de-cat
timax exhaust system cat back
unknown fmic
unknown 38mm ext gate
e-manage blue
330cc injectors
fse rrfpr
walbro 255lph fuel pump
brand new alternator
brand new water pump
brand new oil pump
brand new full seal kit
momo steering wheel
greddy turbo timer
blitz 2 bar boost gauge
hdi boost controller
3g grooved discs
ebc green stuff pads
got st 202 (celica gt) calipers to go on with the spacers needed to centralise the disc in them
lsd gearbox (unsure if oem or aftermarket)
oil catch can
sparco harness
speedline alessio alloys (most common on nova gte's)
cobra 45mm lowering springs on standard newish shockies
is all i can think of at the mo.
Engine
Apexi N1 3"Backbox
SSteel Exhaust System
Corolla Mani
RAM Air Filter
ToyTuning ResoviourCovers
Magnicore ignition leads
Suspension
40mm Koni Sport Suspension
Front Strut Brace
Rear Strut Brace
Interior Floor Strut Brace
Pillar strut Brace
Brakes
255mm x 22mm Vented Grooved Discs
Yellow Stuff Pads
Glanza Calipers
Do-Luck Braided Hoses
Wheels & Tyres
15" Final Speed Eraser A-Tech Alloys
Maxxies 195/45x15
Black D1 Spec Wheel Nuts
Exterior
Window Tints
Wind Deflectors
Square Import Style Number Plates
Front Smoked Indicators
98Spec Rear Cluster Lights
Black Sunstrip
TRD Badges
Raised Bonnet
SARD Carbon Fibre Mirrors
Carbon Reverse Scoop
Carbon Eye Brows
TTE Standard Spoiler
Glanza Back Bumper
Glanza Sideskirts
Glanza Surround
Glanza 98spec Bumper
Glanza Bonnet
Glanza Headlights
Glanza Crystal Fogs
Interior
Recaro Bucket Seats
Recaro Back Bench
Recaro Door Cards
EP91 Arm Rest
TRD Carbon Window Switchers Console
TRD Seat Belt Pads
TRD Short Shifter
TRD Gear Knob
Carbon Fibre Dial Surround
Carbon Fibre Clock Surround
Centre Console Metallic Black
JDM Stickers/Sucker Decals
Glanza Cup Holder
Option Tuning R.P.M Gauge
Option Tuning Volts Gauge
Option Tuning Vacum Gauge
Custom Gauge Surround
JVC Headunit
Standard Front/Back speakers
Plans; 4efte next year, And runing round 200bhp mark. Also some handling mods.
... at the moment at full throttle i think its only about 80-90% duty on the injectors
only 80/90% on 440's for 1 bar ct9? That's far far to much!
have you got an afr plot? id be surprised if your not hitting 10's or lower..
from memory injectors should never be pulsed at more than 85% with 80% being the stnd rule as you will generally loose hp and less fuel will actually be put in!
this is because the pintles within the injector are efectivley hovering because they are trying to open and close again before a full cycle is complete.
Basically Id advise that you get your fueling checked out mate or you could start experincing the pain of borewash :thumbsup:
as she stands imbarrised now with all you lot with all the mods
dumpvalve
boost gauge
rx7 tmic
relocation airfilter
mr2 roadster alloys in black
magnercore lead not fitted yet
iridium plugs 7
polished rocker cover not that thats a mod lol
double din dvd player /sat nav
40 grooved disks and yellow stuff pads
:thumbsup:
Here is a spec of my EP when itl be finished
ENGINE:
Fully rebuilt forged toyota paseo engine
Forged pistons and rods(not sure on make)
Uprated bottom end bearings including thrust washers
Fully rebuilt and gas flowed cylinder head
SPS Clear cam cover
Power flex engine mounts
Ultralite sandwich plate
Defi link controller
Defi boost gauge
Defi oil pressure gauge
Defi water temp gauge
Defi fuel pressure gauge
Defi exhaust temp gauge
Defi oil temp gauge
Defi controller
HDI front mounted intercooler
HKS Hi power silent cat back exhaust
Sard RRFPR
HKS super power flow reloaded induction kit
Camo coolant hoses
Air brushed rocker cover to match camo hoses
Front mount air filter
Tuning developments oil catch tank and resevoir covers
Tong TD-12 Hybrid CT-9
Zisco ram style externally gated manifold
Zisco Decat
External waste gate( not sure make yet)
Greddy Emanage Ultimate
Toyota engine gasket kit
Toyota fuel filter
255lph Fuel pump (not sure on make)
Probs HKS Boost controller
TRANSMISSION:
OEM limited slip diff gearbox
braided clutch hose
TC short shifter
Racing clutch( not sure on make yet)
Lightened flywheel
BRAKES:
Levin twin pot front brake upgrade
Modified front hubs to fit extended wheel studs
Glanza rear disc conversion
Earls braided brake hoses all round
Cusco style BMCS
Toyota 5.1 brake fluid
New glanza rear handbrake cables
CHASSIS/SUSPENSION:
Meister r coilovers
Whiteline adjustable rear anti-roll bar
Fully stripped, reconditioned and painted subframe and supension components.
Whiteline adjustable panhard rod
Whiteline Front ARB
Whiteline Drop links
Whiteline Anti-Lift kit
INTERIOR:
6 point cusco welded in roll cage
Fully stripped interior
Bride Zeta III bucket seat (driver)
Sablet 3 point harness
Fixed bucket for passenger seat
Cusco rear strut brace
Zep c pillar brace
CD dials(maybe Paseo yet)
TRD carbon fibre style dash couling
Custom carbon fibre dial sorrounds x2
Momo race steering wheel
HKB boss kit
TRD gearknob
Apexi turbo timer
Carbon skinned door cards
Flocked Dash board
WHEELS AND TYRES:
Rays TE37's 15" wheels
Toyo proxes all round
Ultralite locking wheel nuts
EXTERIOR:
Starlet remix front bumper with grille
Clear indicator lenses
Crystal n/a headlights
98 spec fog lights
Glanza rear bumper with optional lip
Glanza boot assembley with carbon fibre top spoiler
Carbon fibre ducktail spoiler
Genuine wind deflectors
Fully reprayed shell in 6P2 Green
Black roof
Bump strips removed
Yaris Washer jets
Cost = far to fucking much, alot of time saved on labour as im doing it all my self
Gary
would like to change my spec list as it has drastically changed since sunday
my full on spec as of now is.......literally......naff all lol
totally back to standard now and getting ready to go to the big scrapyard in the sky :thumbsup:
