im thinking of getting a td12 turbo in a few weeks for my starlet and before i do i was just wondering what other turbos there are for a starlet and what bhp they can produce.
can some one tell me please thanks.
im looking for hardly no lag and big bhp hahahahaha lol
something is up with your computer dude, uv repeated the same thing over on a couple posts..
im going for the TD12 because im after quick acceleration, no lag and fair BHP, as mines going to be used for hill climbs etc...
yeh the td12 is way more powerful than the ct9 look in the turbo section theres a thread about it lol
and as far as im aware i think its like a td04 in which you do have to change the manifold etc to put it on lol
for the td12 you need an external wastegate manifold. having a screamer on the decat wont work as there is no internal wastegate. there insnt much lag and it pulls well. i have not had my car dynoed yet but will be soonish and i will post results when i get some
have a look at my build thread if you need to see the manifold etc
marck
ok mate cheers by the way proberly a very stupid question coming up lol but ....
as the waste gate is welded up i take it the actuator is not needed so how is the boost adjusted ??? stupid i know :)
Boost is adjusted by a boost controller, electronic or manual.
Boost is limited by the external wastegate. Will need an external wastegate manifold though. And yes the actuator is not needed.
As the mbc/ebc will hold the external wastegate spring shut until desired boost level is reached then it dumps the excess out the screamer.
eg a external wastegate might have a 0.8bar spring, so anything above that it vents, and the boost controller will hold it shut until whatever has been set by your boost controller, then it wil dump it once that has been reached.
