Jae-Glanza Posted November 30, 2009 Share Posted November 30, 2009 Intercooler arrived today and going to set about fitting it tomorrow! It came with a belt from toy tuning which i'm pretty sure is a non aircon belt. now I'm wondering if i HAVE to remove the aircon as i haven't prepared my self for that, just thought it would be tight with the aircon in! =]UPDATETo save making a new thread i thought i'd just edit my original. Today i fitted the intercooler, Fitted in with hardly any bumper cutting! HOWEVER, The turbo whine now sounds completely different, i'm not sure if this is normal or it's the intercooler leaking a little, and instead of a normal blow off from my shitty bailey, it also has a absolutely lovely flutter! i love in but thought this only happened running a really tight bov or no bov at all. Any ideas? Quote Link to post Share on other sites
WallaceGlanza Posted November 30, 2009 Share Posted November 30, 2009 Depending on what intercooler it is then yes you may need to remove the aircon to fit the pipework, or you'll have to modify the pipework. Quote Link to post Share on other sites
ToyotaTech15 Posted November 30, 2009 Share Posted November 30, 2009 what intercooler is it mate?Gary Quote Link to post Share on other sites
Jae-Glanza Posted November 30, 2009 Author Share Posted November 30, 2009 Autobahn i'm lead to believe mate! Really cba to remove the aircon! Quote Link to post Share on other sites
Jae-Glanza Posted November 30, 2009 Author Share Posted November 30, 2009 Looks identical to the one in the 'removing aircon' guide, which has the fmic fitted before he removed the aircon.http://i2.photobucket.com/albums/y26/saxor...ON/P3170014.jpg Quote Link to post Share on other sites
Idrees Posted November 30, 2009 Share Posted November 30, 2009 It's an easy task to be honest mate. There is a tutorial that shows whats involved over on TGTT. Quote Link to post Share on other sites
Jae-Glanza Posted November 30, 2009 Author Share Posted November 30, 2009 Yea i dont mind doing it if i have to, but if i can avoid taking it out i'd much rather. where are you autobahn cooler owners? Quote Link to post Share on other sites
Dstillie Posted November 30, 2009 Share Posted November 30, 2009 no you dont have to remove the aircon, i fitted a hdi intercooler with air con in and that core is huge i also didnt have to modify any pipework... altho id recommend you get rid its easy enough and you will have loads more space to work with. Quote Link to post Share on other sites
micky boy Posted November 30, 2009 Share Posted November 30, 2009 i thort i could help you there matey but you have a diffrent fmic to what i have got mine must be old school lolhere is a pic anyway Quote Link to post Share on other sites
WallaceGlanza Posted November 30, 2009 Share Posted November 30, 2009 no you dont have to remove the aircon, i fitted a hdi intercooler with air con in and that core is huge i also didnt have to modify any pipework... altho id recommend you get rid its easy enough and you will have loads more space to work with.The HDI has a different piping route though.... Quote Link to post Share on other sites
Jae-Glanza Posted November 30, 2009 Author Share Posted November 30, 2009 I'm pretty sure both sets of piping runs down the battery side of the engine bay. it has the dumpvalve exit right at the top of the all the piping which will result in my dumpvalve being central and at rocker cover height. if that helps folks?I think i can get away with keeping it after searching and a few response from here. Thanks chaps, mucho appreciated x Quote Link to post Share on other sites
dale10ellis10 Posted November 30, 2009 Share Posted November 30, 2009 Just for the input I managed to fit my Jp Performance intercooler kit without removing the air con but ended up having to get rid of it when I got my air filter relocation kit, so if your planning on relocating your filter which is a must if you want any kind of performance gains then get that A/C removed Dale. Quote Link to post Share on other sites
Jae-Glanza Posted November 30, 2009 Author Share Posted November 30, 2009 Thanks dale, Expect i'll fit the cooler if i can without removing the aircon for the minute, then next week with a week off from work i'll take that aircon out!Thanks folks! Quote Link to post Share on other sites
dale10ellis10 Posted November 30, 2009 Share Posted November 30, 2009 Thanks dale, Expect i'll fit the cooler if i can without removing the aircon for the minute, then next week with a week off from work i'll take that aircon out!Thanks folks!No worries, the main issue with my intercooler was the pipe that comes from the turbo and heads downwards to the drivers side of the car, you've got to cut the plastic side cover ( if you still have one ) and the aircon pipe sits right where the pipe wants to go. But obviously with a little delicate bending it cleared it This depends on the make and route of your intercooler pipework.But just a heads up Quote Link to post Share on other sites
Jae-Glanza Posted December 1, 2009 Author Share Posted December 1, 2009 UPDATETo save making a new thread i thought i'd just edit my original. Today i fitted the intercooler, Fitted in with hardly any bumper cutting! HOWEVER, The turbo whine now sounds completely different, i'm not sure if this is normal or it's the intercooler leaking a little, and instead of a normal blow off from my shitty bailey, it dumps followed by a absolutely lovely flutter! i love in but thought this only happened running a really tight bov or no bov at all. Any ideas? Quote Link to post Share on other sites
Jae-Glanza Posted December 1, 2009 Author Share Posted December 1, 2009 Anyone ? ;o Quote Link to post Share on other sites
chr15_7_t_ Posted December 1, 2009 Share Posted December 1, 2009 cant anser your question but i got that lovly sound when i fitted my a/b88 intercooler with a sequential dumpvalve and a front mounted filter Quote Link to post Share on other sites
Jae-Glanza Posted December 1, 2009 Author Share Posted December 1, 2009 Thank-you chris.I'm Running a Autobahn fmic, Bailey bov + hks panel filter.. i love the sound and happy for it to stay ;p but i was just wondering if something was wrong that was creating it.. Did anyone else notice a difference in turbo whine/whistle when boosting when installing the FMIC.Jae Quote Link to post Share on other sites
chr15_7_t_ Posted December 1, 2009 Share Posted December 1, 2009 my turbo dosnt whine as much as it did(but then i have a dif turbo now)...but i still get my full boost along with the sound of the b.o.v and the chatter Quote Link to post Share on other sites
Jae-Glanza Posted December 1, 2009 Author Share Posted December 1, 2009 So you'd say the turbo noise was quieter after you installed the fmic buddy? Mine definately isnt as high pitched! Thanks chris! Quote Link to post Share on other sites
