chriswoodfto Posted December 29, 2009 Posted December 29, 2009 hey, it seems to take quite a while for the temp gauge to get to the right level when i first get in ona morning, (half way between hot and cold) it gets there at a normal speed as long as i dont have the heater on full and hot. if i leave heater off id say it gets there at the right amount of time compared to my latst 5 cars.it blows out pretty hot air when its on hot, but the temp gaige drops very slightly when ive got it on full and hot...thats about all i can tell you. should i flush the rad and fill it with new coolant??? if so, how do i go about doing that? just take the botom hose off, drain all stuff out and re-fill it. or do i need to flush some clean water through it first??cheers Quote
lukEp Posted December 29, 2009 Posted December 29, 2009 replace the thermostat with a new one common fault its stuck open meaning its alway running water into the rad to cool it no matter what the temp is at hence taking ages for it to warm upluke Quote
chriswoodfto Posted December 29, 2009 Author Posted December 29, 2009 ahhhhh, cool, ill do that then, weres the thermostat located?? Quote
lukEp Posted December 29, 2009 Posted December 29, 2009 not sure were about on the engine but follow the top hose from rad to the engine and it'll be round the place were the hose connect to the engine will have 2-3 10mm bolts holding a cap over it Quote
chriswoodfto Posted December 29, 2009 Author Posted December 29, 2009 your a star, cheers mate. Quote
lukEp Posted December 29, 2009 Posted December 29, 2009 no prob hope you sort it keep us updated if you fix it and how you fixed it for other with a same/similar problem so they can use the search instead of asking again Quote
chriswoodfto Posted December 30, 2009 Author Posted December 30, 2009 will do, ill take some pics when im doing it, i think its the botom hose that has the thermostat in near the block because theres a cap on the block there. just a quick question, im guessing i do but does all the plastic trim under the bumper/engine need to come off to get at the botom hose? im guessing yes because i cant get to it form the top. cheers guys. Quote
Asad Posted December 30, 2009 Posted December 30, 2009 Is the heater dial on cold or hot when this happens? turn it to cold and it will heat up alot faster then see what happens Quote
micky boy Posted December 30, 2009 Posted December 30, 2009 ^^yep thats what i do turn all the fans off and put the heater on cold it heats up much faster Quote
chriswoodfto Posted December 30, 2009 Author Posted December 30, 2009 yea, it heats up quicker when i do that but its bloody freezing!!! ive got a new thermostat anyways, cant be fooked to do it today though, ill do it monday when i lower it because ive gota piss about takin all that plastic trim off underneath. Quote
