Dan Evans Posted January 3, 2010 Posted January 3, 2010 I've only just noticed a little sticker on the drivers side which is all in japanese, but it does have ABS & LSD on the sticker, would that mean i have got an LSD or not?i havent taken the box out yet however that will be happening soon to replace the clutch..any help on this would be great cheers guys. Quote
micky boy Posted January 3, 2010 Posted January 3, 2010 Hello matey no i think it just means the weight of the car with lsd or non lsd my old glanza had that sticker and it never had lsd You could still have lsd though all im saying is that sticker doesn't mean you have got lsd, if you have a good look at an lsd gearbox and a non lsd gearbox you will see the diffrence then you will know if yours has lsd or not lol Quote
silverglanza Posted January 3, 2010 Posted January 3, 2010 doesnt mean anything your gear box code would be different to mine ill get mine later whats yours say its on your data plate behind your strut brase Quote
micky boy Posted January 3, 2010 Posted January 3, 2010 also i think on a non lsd gearbox it will have 188 written in pink on the gearbox the same side as where the thermostat is if you look below the thermostat you should see it, hope that helps im not a 100% sure so dont take my word for it lol Quote
Dan Evans Posted January 3, 2010 Author Posted January 3, 2010 il get the code, so is it the silver plate your on about? il get all he codes off it in abit, cheersyeah mine has 188 in pink writing, i thought the car had a different gearbox on it lol Quote
micky boy Posted January 3, 2010 Posted January 3, 2010 right dan lol the top pic is an lsd box the bottom pic is a non lsd box,if you look at the lsd box it has a big chunky bit where the shaft gos in thats the lsd, then if you look at the non lsd box it doesn't have a chuncky bit lol Quote
micky boy Posted January 3, 2010 Posted January 3, 2010 lol i hope you dont mind me borrowing a pic of it jason Quote
jason_l Posted January 3, 2010 Posted January 3, 2010 lol i hope you dont mind me borrowing a pic of it jason LOL Not my pic, haven't picked it up yet....... Quote
Kennedy Posted January 3, 2010 Posted January 3, 2010 I posted the samething a while ago, i'll find the threadLink Quote
Dan Evans Posted January 3, 2010 Author Posted January 3, 2010 i think mine is just like the top one!!! however, i will double check, cheers lads Quote
rmsnoel Posted January 27, 2010 Posted January 27, 2010 If it has a aftermarket LSD tell him about the jack one wheel up and try to spin it, if you have lsd it'll stop after so many turns etc.? Quote
