200bhp starlet Posted January 12, 2010 Share Posted January 12, 2010 i got a driveshaft for my 97 glanza from 24/7 spares it came yesterday and has like half the hub connected to it just wondered if this is normal and can you split it from the hub so its just the shaft thanks for looking Quote Link to post Share on other sites
WallaceGlanza Posted January 12, 2010 Share Posted January 12, 2010 Yes, undo the hub nut and bash it out. Quote Link to post Share on other sites
200bhp starlet Posted January 12, 2010 Author Share Posted January 12, 2010 WallaceGlanza said: Yes, undo the hub nut and bash it out.ok will do thanks matey Quote Link to post Share on other sites
micky boy Posted January 12, 2010 Share Posted January 12, 2010 Thats if the outer joint isnt seized to the hub, if it is you will have to split the cv joint from the hub, and get a new joint Quote Link to post Share on other sites
200bhp starlet Posted January 12, 2010 Author Share Posted January 12, 2010 micky boy said: Thats if the outer joint isnt seized to the hub, if it is you will have to split the cv joint from the hub, and get a new joint cheers mickyboy gettin to the end of my patience now with the car cant get that f**king bolt out the gearbox snapped 2 ez outs also when my engine mount gave up and the driveshaft came out do you think it would of done much damage ti it i was only doing bout 25mph and stopped straight away it just come out of the knuckle thing by the gearbox ???? Quote Link to post Share on other sites
