ive seen the other thread and it didnt really explain so...
i have a 1999 sr n/a and one of the number plate bulbs is on its way out, it need replaced
what bulb do i ask for over the counter? is this easy done?
thanks GOOD TO BE BACK thanks moders
i tried changing mine, but how the heck do you get them damn funny pop in screw things out!! Took me ages to just get one out :thumbsup:
Hold the outer ring of the screw and then unsrew the middle then it should come out a little, just enough for you to get your nails on to pry it out. Did mine yesterday. Then when you get the cover off all you have to do is rotate the connection on the bulb about 90 degrees and it should come out with the bulb attatched. None of the taking off bulb cover pish.
