Glanza_Lee Posted January 26, 2010 Posted January 26, 2010 Looking at a set of Glanza dials on ebay as I need to change mine from 110 back to 180. However, as its the whole instrument cluster thats for sale, am I able to take out the odometer and put the one from mine into the new one? The reason im asking is because if I cant, the mileage will be higher than what it actually is! Quote
lukEp Posted January 26, 2010 Posted January 26, 2010 Looking at a set of Glanza dials on ebay as I need to change mine from 110 back to 180. However, as its the whole instrument cluster thats for sale, am I able to take out the odometer and put the one from mine into the new one? The reason im asking is because if I cant, the mileage will be higher than what it actually is!the odometer and speedo are all one unit you just need to change the face of the speedo did you fit the new face or was it already on? As the original face might be under the new one. Quote
Glanza_Lee Posted January 26, 2010 Author Posted January 26, 2010 I didnt think of that. The new face was put on by someone else. I'll take the cluster out of mine and see if the original is behind the new face. I hope it is, will be much easier and less hassle for me. How do you take the faces off? Quote
Glanza_Lee Posted January 27, 2010 Author Posted January 27, 2010 Yeah but once the cluster is out, can you remove the clear plastic bit at the front? Quote
bucketep91 Posted January 27, 2010 Posted January 27, 2010 1ce u take the plastic bit out the clear cluster comes out then there are little screws to take the dail face off but u could just bend it back a little to see idf the original face is there Quote
Glanza_Lee Posted January 27, 2010 Author Posted January 27, 2010 Thanks mate. I'll do that once I get the car back. Quote
