dunno if im right or not but does the fuel not just keep comin out ? i found some instructions on the net and had the car runnin and pulled out the fuel relay to use up any fuel in the system . however it was pointless because i got the fuel from the filter everywhere anyway :thumbsup:
And risk running the car lean or with no fuel? Not what i'd want on a turbo engine!!! I'd happily spill some fuel rather than kill an engine
Damien
well its the way people have recomended. and it takes less than a second to cut out so its not really running. and i fail to see how i could run an engine with no fuel lol
out of intrest, dont suppose there will be, but are there any better fuel filters than others? or is it just literally oe bits. again suppose itll matter but its always filled with v-power since i bought it.
one thing to watch out for is i bought a filter from tmd i think. nothing wrong with the filter but the one that was on the car ( i would think it was from toyota ) has a bracket welded onto it so it can be bolted to the firewall. the ones most people sell dont have this. could use an old filter and a bit of metal to make a bracket up tho. just get a flat bit metal and hammer it round a filter for the shape then drill 2 holes and should be decent. if you have a look at your filter you should see what im on about.
lol. i read your old post this morning mate, ill make sure i buy one with the bracket on, failing that ill do what you recomended, abit of aluminium can would bend round a peice of piss, might even be able to incoperateit into a red bull can or sumit, seen it done before on diferent cars..
