Dan Evans Posted February 2, 2010 Share Posted February 2, 2010 ok, as some of you are aware I've had a problem with the engine management light coming on at about 2500 revs, followed this VERY helpfull guide http://www.ukstarletclub.com/forums/index.php?showtopic=1563 and it brought up error 52 which is the knock sensor..basicly what im wanting to know are the following...1. were abouts is the knock sensor in the engine bay (pictures please!!!)2. why would this have occured3. is it bad???cheers guys, any help on this would be much appreciated as I've never been envolved with knock sensors, cheers. Quote Link to post Share on other sites
Idrees Posted February 2, 2010 Share Posted February 2, 2010 Ah I was right then!1. The sensor is under the inlet manifold. If your facing the engine bay, then its on the left of the inlet just underneath it.2. The wire might have been cut or damaged. It's only a single wire so can easily break, had the same problem in the past.3. As long as you get it sorted you'll be fine. I think the ECU will go on Safe mode if it doesn't get a knock reading. The car will usually go shit slow too, well our old GT did. It didn't even boost proprly, but once the knock sensor back on it was flying again.Hope that helps. Quote Link to post Share on other sites
Dan Evans Posted February 2, 2010 Author Share Posted February 2, 2010 massive help mate, yes you were right lolil have a look now, it runs fine and its only stuttering when on full boost (sometimes)cheers buddy Quote Link to post Share on other sites
micky boy Posted February 2, 2010 Share Posted February 2, 2010 i dont have a pic but its under the manifold it looks like a big nut lol with a sensor comeing off it if i was you dan id chech to make sure the the lead that gos to the sensor is on right I've know the lead going to the knock sensor come off Quote Link to post Share on other sites
Dan Evans Posted February 2, 2010 Author Share Posted February 2, 2010 I've just had a quick look but cant see it for the life of me, if its possible guys could you find a picture of an engine out and roughly show me were it goes?? sorry to be a pain in the asswould it be better to get underneath the car? Quote Link to post Share on other sites
Dan Evans Posted February 2, 2010 Author Share Posted February 2, 2010 ok i found the sensor, it all seems fine... so now wot?how am i going to resolve the issue and stop the engine management light coming on??PLEASE HELP GUYS!!!!! getting fucked off now lol :harhar: Quote Link to post Share on other sites
micky boy Posted February 2, 2010 Share Posted February 2, 2010 Are you 100% sure its the knock sensor? what management are you runing cause when i was runing the power fc in my old glanza the engine management light was flickering through the revs not on tick over and it was doing it because i was useing shit fuel it sounds silly i no but the ecu was mapped for hi octane fuel so when i put shit fuel in it change the timeing and the ecu didnt like it if you get me lol Quote Link to post Share on other sites
Dan Evans Posted February 2, 2010 Author Share Posted February 2, 2010 it comes up code 52.I've used both types of fuel and never had issues before.I've got a different actuator but doubt that would have an effect.its all standard fueling,ecu etc..WOT now!!!!! lol Quote Link to post Share on other sites
micky boy Posted February 2, 2010 Share Posted February 2, 2010 As alway its the cold weather its fuel cuting turn the actuator down a bit just one full turn, thats your best bet if that dont sort it then fuck knows lol Quote Link to post Share on other sites
Dan Evans Posted February 2, 2010 Author Share Posted February 2, 2010 yeah I've turned it down now, il try it and see.is there anyway to re-set it?? Quote Link to post Share on other sites
micky boy Posted February 2, 2010 Share Posted February 2, 2010 on the stock ecu you should be able to just turn the engine off then restart it and it should be reset if not then disconnect the battery for 20min Quote Link to post Share on other sites
Idrees Posted February 2, 2010 Share Posted February 2, 2010 Follow up the wire from the knock sensor and check for any damage/cuts? Quote Link to post Share on other sites
micky boy Posted February 2, 2010 Share Posted February 2, 2010 buy my ecu dan then all this want happen :harhar: Quote Link to post Share on other sites
Dan Evans Posted February 2, 2010 Author Share Posted February 2, 2010 what ECU ya got mate?will do iddy Quote Link to post Share on other sites
micky boy Posted February 2, 2010 Share Posted February 2, 2010 blitz access ecu matey plug and play Quote Link to post Share on other sites
Dan Evans Posted February 2, 2010 Author Share Posted February 2, 2010 hhhhhhhhhhhhhhhhhhhhhhmmmmmmmmmmmmmmmmmm how much?? Quote Link to post Share on other sites
micky boy Posted February 2, 2010 Share Posted February 2, 2010 £450 posted thats what i paid for it and thats what they go for lol no more fuel cut lol Quote Link to post Share on other sites
Dan Evans Posted February 2, 2010 Author Share Posted February 2, 2010 hmm tempting.........i shouldnt be hitting fuel cut though, I've got a JAM FCD. Quote Link to post Share on other sites
micky boy Posted February 2, 2010 Share Posted February 2, 2010 That could be wiried in rong or been nocked lol the blitz ecu will set your dreams a light lmao Quote Link to post Share on other sites
Dan Evans Posted February 2, 2010 Author Share Posted February 2, 2010 hmmm lol Quote Link to post Share on other sites
micky boy Posted February 2, 2010 Share Posted February 2, 2010 :harhar: you will still be able to sell it for the same price when you come to do the 5efe ;) Quote Link to post Share on other sites
Dan Evans Posted February 2, 2010 Author Share Posted February 2, 2010 il have a think on, il try and sort it, if not, then il PM you.cheers bud Quote Link to post Share on other sites
micky boy Posted February 2, 2010 Share Posted February 2, 2010 ok dan no bother mate :harhar: Quote Link to post Share on other sites
Dan Evans Posted February 2, 2010 Author Share Posted February 2, 2010 woo hoo!! its fixed!!until i test it for sure tomorrow, but its now flashing on and off constantly which means NO ERRORS!!woop woop Quote Link to post Share on other sites
micky boy Posted February 2, 2010 Share Posted February 2, 2010 what was it? Quote Link to post Share on other sites
