chr15_7_t_ Posted February 26, 2010 Posted February 26, 2010 not for another half a year but want to make sure if i stil have the car that it flys thruw i have the power steering removed from my ep82 at the moment... will this efect the m.o.t?what are comon failures for starlets for m.o.ts? Quote
Starlet__SR Posted February 26, 2010 Posted February 26, 2010 Not if it's been removed correctly, no loose hoses, common failures are just general maintenance items, bushes, bearings, bulbs, not too sure how the imports do on emissions, just give it a once over every month, check everything is okay, it pays off.Damien Quote
chr15_7_t_ Posted February 27, 2010 Author Posted February 27, 2010 how do i remove it corectly? might sound a bit rough but as i might put it back in all ive done is took the pump,mounts n belt off and blocked the hose. Quote
ToyotaTech15 Posted February 27, 2010 Posted February 27, 2010 It will fail if you have no power steering but still have the power rack fitted,You will need to change to a non-power steering rack if you want to pass that wayGary Quote
ktl Posted February 27, 2010 Posted February 27, 2010 rear fog lights work, and if you got harnesses make sure there "e" marked! Quote
