it would not fit mate, the runners are spaced too far apart, you would also have isues with the tb, linkages etc
Neither th Inlet or Exhaust Manifolds would fit as its a different engine series (4E and 5E are the same E series)
the 1.8 from the Avensis is the 7A which is a A series engine :lol:
Hope this helps
Kind Regards,
Nick Jones
Tuning Developments LTD
Workshop Landline - 01925 822266
www.TuningDevelopments.co.uk
TuningDevelopments@Hotmail.com
no but the 7afe exhaust mani can be made to fit as the exhaust runners are exactly the same diameter and only mm diferent with the 2 central runners being the corect distance apart just the outer 2 needing to be brought in a few mm!! some 7afe's also used a stainless 4-2 and mild steel 2-1 and they are cheap and readily available!! just needs the flange cutting off and re welding to to a 4e flange!
