batmanglanza Posted March 29, 2010 Share Posted March 29, 2010 hi.i hav a glanza and i have a big problem with it. its smoking big time. i have got thick white smoke coming out the exhaust. I changed the turbo and the problem is stil there. I have got oil coming out from underneath the bonnet somewhere too. i cant figure out wot it is? does anyone know wot it cud be. Quote Link to post Share on other sites
Guest cheshireglanza Posted March 29, 2010 Share Posted March 29, 2010 ^^ forgot i had to come see you are you home bout 8 dude will have look for you Quote Link to post Share on other sites
micky boy Posted March 29, 2010 Share Posted March 29, 2010 Is the oil comeing out of the cam cover breathers? Quote Link to post Share on other sites
batmanglanza Posted March 29, 2010 Author Share Posted March 29, 2010 Is the oil comeing out of the cam cover breathers? theres shit loadsa oil in the exhaust and the breather on top was spittin oil out too. Quote Link to post Share on other sites
batmanglanza Posted March 29, 2010 Author Share Posted March 29, 2010 theres shit loadsa oil in the exhaust and the breather on top was spittin oil out too.BUMP Quote Link to post Share on other sites
micky boy Posted March 29, 2010 Share Posted March 29, 2010 Shit i forgot about you lolIs there alot of oil comeing out of the rocker cover breather? if so your piston rings (could) be on there way out. Quote Link to post Share on other sites
Socks Posted March 29, 2010 Share Posted March 29, 2010 White smoke from the exhaust if not your turbo may be your headgasket mate!? Dont continue to run it. get your head skimmed and a new gasket in there and see if it solves your issues! Quote Link to post Share on other sites
GAZ@A&G_TUNING Posted March 29, 2010 Share Posted March 29, 2010 prob your ring's, but start with the simple stuff, compression check then a wet compression check, if it seems ok, try a new pcv valve which is on the rocker cover and connects back up to the inlet mani, only 25 quid ishhow does the car drive? is is sluggish ? Quote Link to post Share on other sites
batmanglanza Posted March 29, 2010 Author Share Posted March 29, 2010 prob your ring's, but start with the simple stuff, compression check then a wet compression check, if it seems ok, try a new pcv valve which is on the rocker cover and connects back up to the inlet mani, only 25 quid ishhow does the car drive? is is sluggish ?the car drives sluggish but it runs. has anyone got any engines for sale? Quote Link to post Share on other sites
micky boy Posted March 29, 2010 Share Posted March 29, 2010 Yep there's one here mate http://www.ukstarletclub.com/forums/index....showtopic=28438 Quote Link to post Share on other sites
batmanglanza Posted March 29, 2010 Author Share Posted March 29, 2010 Yep there's one here mate http://www.ukstarletclub.com/forums/index....showtopic=28438has anyone got any cheaper engines? Quote Link to post Share on other sites
