Hopefully an easy one.
If I were to remove the Jam ECU and replace it with a standard one would i need to do anything more?
Or is it literally disconnect JAM ECU connect standard one?
Thanks in advance.
Depends if you have any other mods such as a hybrid turbo etc?
The ecus will be a straight swap..but you may need a FCD etc if you are boosting above standard
Ill be returning the car to standard. So if I remove the Jam ECU ill put it to stock boost. Also just a CT9b no hybrid.
  • 2 weeks later...
