whats the part number for the small oil seal on the oil pump thats for the crank. was at toyota today and ordered one but on the system 2 came up for the engine. on dates early 96 til late 96 and the other one was for 96 onwards. left me a bit confused.
this is for 96 glanza v
15100 PUMP ASSY, OIL15100-11071 4EF*..EP9* 1 $154.3115100-11071 4EFTE..EP91 1 $154.3115100A PIN, RING (FOR OIL PUMP SET)90253-09001 4EF*..EP9* 2 $1.3715100B RING, O (FOR OIL PUMP)90301-62006 4EF*..EP9* 1 $3.3115100C SEAL (FOR OIL PUMP)90029-21020 4EF*..EP9* 1 $6.3215100P PULLEY, OIL PUMP DRIVE SHAFT13524-11020 4EF*..EP9* 1 $21.1215100R SENSOR, CRANK POSITIONNot applicable15101A SEAL (FOR CRANKSHAFT)90311-35035 4EF*..EP9* 1 $9.7390311-35040 4EF*..EP9* 1 $10.3515102 ROTOR SET, OIL PUMP15102-11080 4EF*..EP9* 1 $50.1915104 STRAINER SUB-ASSY, OIL15104-11190 4EFTE..EP91 1 $80.1115104A RING, O (FOR OIL STRAINER)96721-24015 4EF*..EP9* 1 $3.1915310H REGULATOR ASSY, OIL15310-10010 4EF*..EP9* 1 $35.4690105-06011 *** STD. PART $0.7590119-06084 *** STD. PART $1.2990179-09004 *** STD. PART $1.8791511-60622 *** STD. PART $1.2891643-80620 *** STD. PART $1.07
hope this helps mategoogle_protectAndRun("render_ads.js::google_render_ad", google_handleError, google_render_ad);
yeh sure thats the one i got but it was bringing up 2 options. its ordered now anyway so i guess ill just wait n see lol. thanks tho. ill tke that number with me just to check.
