starlybruiser Posted April 10, 2010 Posted April 10, 2010 Ive fitted a new boost controller and atm just want to run 0.8 bar but just wondered what my actuator should be set to? atm its 0.7 bar will it be ok to leave at this? also if I set the boost controller at 0.4bar and the actuator still being at 0.7bar will this still be ok and drop down to 0.4 bar? cheers Quote
mr karnage Posted April 10, 2010 Posted April 10, 2010 doesnt fuel cut come in after 0.8 and im sure it would be alright at 0.7 unless you get boost creep, if not then i would leave it at 0.7, more boost Quote
DavidAshton Posted April 10, 2010 Posted April 10, 2010 You can only boost above your actuator level, not below.0.7 bar actuator with 0.8 bar via boost controller will work fine. Quote
starlybruiser Posted April 11, 2010 Author Posted April 11, 2010 You can only boost above your actuator level, not below.0.7 bar actuator with 0.8 bar via boost controller will work fine.Got the actuator at 0.5 bar now and set one channel at 0.8 bar and the other at 0.6 works very nicely boost comes in so much smoother and a bit quicker now, havent played with the gain setting yet tho, hopefully I can get the spooling that extra bit quicker without getting any spiking Quote
DavidAshton Posted April 11, 2010 Posted April 11, 2010 Boost controller you using out of interest? Quote
starlybruiser Posted April 11, 2010 Author Posted April 11, 2010 Just fitted a Blitz DSBC Spec S, well pleased with its performance, and its so easy to setup, just gunna play with the Gain Feature a bit when I get the chance Quote
Matt Glanza Posted April 11, 2010 Posted April 11, 2010 Just fitted a Blitz DSBC Spec S, well pleased with its performance, and its so easy to setup, just gunna play with the Gain Feature a bit when I get the chance wouldnt have the actuator at a lower setting than stock.i had probs when i did that Quote
starlybruiser Posted April 11, 2010 Author Posted April 11, 2010 wouldnt have the actuator at a lower setting than stock.i had probs when i did thatSo you rekon I should have it set a bit higher? got it at 0.5 bar atm, would 0.6 be better? also any advise when playing with the Gain? Cheers mate. Quote
Matt Glanza Posted April 11, 2010 Posted April 11, 2010 So you rekon I should have it set a bit higher? got it at 0.5 bar atm, would 0.6 be better? also any advise when playing with the Gain? Cheers mate.what ever stock is think its .6 so yea.just dont boot it staight away if its slow winding up to you set boost then you need more gain.adjust until it goes straight to the set pressure.unsure on those if thelower the number the more gain or the other way?hav a play and see. Quote
starlybruiser Posted April 11, 2010 Author Posted April 11, 2010 what ever stock is think its .6 so yea.just dont boot it staight away if its slow winding up to you set boost then you need more gain.adjust until it goes straight to the set pressure.unsure on those if thelower the number the more gain or the other way?hav a play and see.Ok nice one mate, will have a play and see how it goes, thanks mate Quote
Glanza_Ragger Posted April 19, 2010 Posted April 19, 2010 Youll love the gain setting its a case of playing with it, untill it boosts nice and fast but with out any spikes.Best way to do it, is keep upping the gain untill it starts to spike, then knock it down a few % for when its uber cold outside. Quote
Carl. Posted April 19, 2010 Posted April 19, 2010 when i set my actuator to 0.8 bar or less it takes forever to spool up (above 4k revs) but one turn above 0.8 and it spools up at 2000 - 2500 like it should. so at minute im driving round with it set above fuel cut so it boosts quicker but i cant boot it because of fuel cut. Quote
Glanza_Ragger Posted April 19, 2010 Posted April 19, 2010 when i set my actuator to 0.8 bar or less it takes forever to spool up (above 4k revs) but one turn above 0.8 and it spools up at 2000 - 2500 like it should. so at minute im driving round with it set above fuel cut so it boosts quicker but i cant boot it because of fuel cut. a few people have that trouble. are you running a boost controller?also does it shoot to 0.5bar then from 0.5bar to 0.8? as if its boosting in 2 stages ? Quote
scot-ish Posted April 19, 2010 Posted April 19, 2010 wouldnt have the actuator at a lower setting than stock.i had probs when i did thatshould make no difference, same job the standard hi-lo boost controller done. Quote
