just got my hks but instructions r jap bit confused whether to have a go myself reckon i could prob do it but dunno whether to n e 1 got a guide or info on how to measure etc do u no n e garages in maidstone that would stick it on fairly cheap not a massive job is it lol done a oil change n service before shall i give this a go dont like playin witrh turbos??
dude you cant go wrong
2 bolts that hole the plate to the compression hosuing and a spring clip holing the pin through the wastegate flap arm
set your actuator arm up and happy boosting
just follow the little diagrams u'll figger it out :)
even tells you how long the arm needs to be for standard setup (128mm is in my head for some reason, i doubt my memory is that good though)
*NOTE* Its not hard to do infact its a piece of piss lol.....I would also get your self a boost gauge so you can get the best results out of you actuator befor you hit fuel cut!!!
yeh i got a guage only thing is weni boost and let throttle of as needle comes down it flicks about could i have an air leak or is my guage shit? i no my actuator is playin up but dunno obut boost guage ?
Your gauge is shit lol....Mine done the same thing but it should still give you some sort of idear what you are boosting untill you buy a good gauge just like i have done :)
Good luck with it matey
thanks mate
hello people me agin fitting me actuator today and am confused there is a small gold cylinder that goes into the piping in the picture im confused as what is it actually for and why the hell its in there? so y does the cylinder go in there?? any info would be apreciated ?
It's a restrictor to help stop the boost spiking.
guys i just wanna say thanks to all fitted my actuator today and what a major improvement im holding boost all way through rev range im running 0.7 bar just to be safe dont wanna hit fuel cut it creeps a little but what a improvement thanks for evry1's help :(
