ro55ifumi Posted May 1, 2010 Posted May 1, 2010 Can you put a car through an mot with a de cat pipe fitted, I have heard you can as the cars are imports Quote
Matt Glanza Posted May 1, 2010 Posted May 1, 2010 If it's newer than a 95 then it has to go through a basic cat test as there is no engine code info for the glanza.I had this problem till I found that because my engine came out of a 91starlet just an idle test Quote
shelly_star Posted May 2, 2010 Posted May 2, 2010 Depends on your MOT garage too, some can just be complicated because they want to be hope you'll pass with flying colours. Quote
silverglanza Posted May 2, 2010 Posted May 2, 2010 sweet so the glanza will pass with decat fitted why is this then ...? Quote
Ryan Milne Posted May 2, 2010 Posted May 2, 2010 sweet so the glanza will pass with decat fitted why is this then ...?Not a guarantee it will pass, it may pass. Quote
shelly_star Posted May 2, 2010 Posted May 2, 2010 There is a flow chart that you can print out for your MOT guy which can found on here somewhere, i did have it saved on my laptop but somehow it's disappeared, but yeah, all i did was printed that out and gave it to my MOT guy and said that my car doesn't need a cat test Quote
silverglanza Posted May 2, 2010 Posted May 2, 2010 any one got this chart this is like music to my ears ? Quote
shelly_star Posted May 2, 2010 Posted May 2, 2010 Right found it, it's not a very clear chart but its readable Not sure if this will help everyone as I said all garages are different or can be complicated.Hope it helps peeps Quote
Steve GT Posted May 2, 2010 Posted May 2, 2010 If it's newer than a 95 then it has to go through a basic cat test as there is no engine code info for the glanza.I had this problem till I found that because my engine came out of a 91starlet just an idle testcorrect ^^^ glanzas need a basic cat test while gt's before 95 only need a basic idle test which anything could pass is all because theres no info on them on the VOSA database cause there only jap importsthings like scoobs and skylines shit out on this cause theres uk equivalents on thesecheck with the mot tester before hand to make sure hes aware of this Quote
ro55ifumi Posted June 5, 2010 Author Posted June 5, 2010 Just taken the car with the mods fitted and passed at a very nice garage Quote
