deano Posted May 1, 2010 Share Posted May 1, 2010 Does anyone have any idea as to what causes the tick over needle to fluctuate. I have cleaned the i c v, put new leads, plugs and fuel filter on. The car is a 1998 bog standard 60,000 mile manual turbo ep91. The only thing i have not changed is the dizzy cap and rotor arm which i have just ordered from camskill. When i pull the plug on the i c v there is no change in the idleing does this mean it's nacked because it is starting to do my nut right in Quote Link to post Share on other sites
Nayls Posted May 1, 2010 Share Posted May 1, 2010 Does anyone have any idea as to what causes the tick over needle to fluctuate. I have cleaned the i c v, put new leads, plugs and fuel filter on. The car is a 1998 bog standard 60,000 mile manual turbo ep91. The only thing i have not changed is the dizzy cap and rotor arm which i have just ordered from camskill. When i pull the plug on the i c v there is no change in the idleing does this mean it's nacked because it is starting to do my nut right in mine does the same! fluctuates about 150rpm & pops from the exhaust like tiny misfires.i've not tried pulling the plug on my icv to see if it changes though. Quote Link to post Share on other sites
boxy_boy Posted May 1, 2010 Share Posted May 1, 2010 sounds like air flow meter my mates ran horribble try borrow a mates air flow meter and see if that helps ive heard a bad bang or bad pothole can f**k it up Quote Link to post Share on other sites
deano Posted May 1, 2010 Author Share Posted May 1, 2010 mine does the same! fluctuates about 150rpm & pops from the exhaust like tiny misfires.i've not tried pulling the plug on my icv to see if it changes though.Mine does not pop or bang just fluctuating idle other than that its as sweet as a nut. Quote Link to post Share on other sites
deano Posted May 1, 2010 Author Share Posted May 1, 2010 sounds like air flow meter my mates ran horribble try borrow a mates air flow meter and see if that helps ive heard a bad bang or bad pothole can f**k it upWhere is that located and what does it look like bud this car i bought for the misses i have a supra so just getting to grips with these. cheers Quote Link to post Share on other sites
boxy_boy Posted May 1, 2010 Share Posted May 1, 2010 its near the airbox or airfilter its just after your air filter there is a plug coming out of it just for an instance unplug it from the air flow meter see if it trys to rectify itself or changes its idel pattern Quote Link to post Share on other sites
deano Posted May 1, 2010 Author Share Posted May 1, 2010 its near the airbox or airfilter its just after your air filter there is a plug coming out of it just for an instance unplug it from the air flow meter see if it trys to rectify itself or changes its idel patternI will give it a go tommorow. cheers Quote Link to post Share on other sites
boxy_boy Posted May 1, 2010 Share Posted May 1, 2010 no probs let me know if it works Quote Link to post Share on other sites
lukEp Posted May 2, 2010 Share Posted May 2, 2010 Starlet don't have an air flow meter, the n/a has a temp sensor near the air box but it's bolted in to the manifold on the turbo, starlets measure air from the map sensor which is a little black box on the bulk head on the drivers side it has a 4mm tube going to it and it will be mounted higher than the manifold in the 4mm tube it will have a small inline filter about 3-4 inches below the map sensor. Quote Link to post Share on other sites
deano Posted May 2, 2010 Author Share Posted May 2, 2010 Starlet don't have an air flow meter, the n/a has a temp sensor near the air box but it's bolted in to the manifold on the turbo, starlets measure air from the map sensor which is a little black box on the bulk head on the drivers side it has a 4mm tube going to it and it will be mounted higher than the manifold in the 4mm tube it will have a small inline filter about 3-4 inches below the map sensor.cheers relised that when i started looking. It also drops a fair bit when the headlights are turned on as well what a pain in the arse. Quote Link to post Share on other sites
Asad Posted May 2, 2010 Share Posted May 2, 2010 Have you checked all the earth points? -ve battery terminal? Quote Link to post Share on other sites
deano Posted May 3, 2010 Author Share Posted May 3, 2010 Have you checked all the earth points? -ve battery terminal?They all seem pretty good but i will go through them again Quote Link to post Share on other sites
deano Posted May 4, 2010 Author Share Posted May 4, 2010 They all seem pretty good but i will go through them againWent in to toyota today and spoke to one of the technisions he said the idle control valve which has been described on hear has more to do with the air con so i tried puling the plug off while the air con was on and low and behold the revs droped. He said they recently had someone in with the same problem and it turned out to be the water temp sensor. I don't realy understand what the water temp sensor has to do with the idle, maybe someone might be able to shed some light ;) Quote Link to post Share on other sites
5T4R7ET N/A Posted May 4, 2010 Share Posted May 4, 2010 basically the water temperature sensor will tell the ecu if the engine is cold or hot.if hot idle lower (normal operating temp) and if cold idle higher.i presume if the sensor is not working properly you could get fluctuating idle as the sensor keeps changing it mind on whether its hot or coldi remember someone else having replaced this part resolved their problem. this could be the case for you. you might as well try, its a cheap fix. here's a link clicky ;) Quote Link to post Share on other sites
deano Posted May 4, 2010 Author Share Posted May 4, 2010 basically the water temperature sensor will tell the ecu if the engine is cold or hot.if hot idle lower (normal operating temp) and if cold idle higher.i presume if the sensor is not working properly you could get fluctuating idle as the sensor keeps changing it mind on whether its hot or coldi remember someone else having replaced this part resolved their problem. this could be the case for you. you might as well try, its a cheap fix. here's a link clicky ;)That makes sense, thanks for the link. The one at camskill is for models up to 97. Mine is a 98 do you think it will be the same because toyota quoted £57 Quote Link to post Share on other sites
5T4R7ET N/A Posted May 4, 2010 Share Posted May 4, 2010 tbh i'm not 100% sure myself because. cant understand why they would be different. but could be wrongbest bet would be to ask camskill because £57 is expensive! Quote Link to post Share on other sites
deano Posted May 5, 2010 Author Share Posted May 5, 2010 tbh i'm not 100% sure myself because. cant understand why they would be different. but could be wrongbest bet would be to ask camskill because £57 is expensive!Checked with camskill they do have 2 the one i need is £48 + p&p is a few quid short of Toyota. Anywho had a little development today i noticed my lower rad hose is not getting warm it is staying cold so i would think my probs are steming from a stuck thermostat. I will change tommorow and keep you all posted of the outcome. Need it ready for RCSC this weekend or the misses will have me nuts. I haven't even had chence to wash me supra yet kin ell Quote Link to post Share on other sites
