Rele Silly Question?
EP82 is behind the centre console
^^^ correct
its behind the centre concole just above where the floor rises
it might be in an ECU cover but to undoe it you need to take a 12mm (i think) bolt out of the bracket on the passenger footwell side then go to the drivers footwell and take out the 2 clip leads and a couple of screws then it will pull out on the passenger side matey
^^^ correct
cheers very muchly :)
lol, what i ment was if he takes the glovebox off he will be able to see it clearer unless its got the black cover on it
chhheeeeshhh, bunch of women :)
also wallace? care to explain what you ment by that remark?
It's something called a joke since you have "smarter than einstien" in your sig. :)
As said the ecu isn't behind the glove box on the ep82's.
