i dont know if im being fussy, but hey here goes...
my engines spec is:
jasma exhaust
blitz decat
TM manifold
blitz access ecu
hks actuator
TT filter relocation kit
HDI front mount intercooler
MM oil catch tank
magncore ht leads
irdium spark plugs g7
wen the actuator arrived i ran a boost pipe thru thwe window to setup the boost to 1bar....
however now ive set it up permanently in the car and ive noticed sumthing....
I only get a full 1bar of boost at about 5000rpm....
im at 0.7bar by 3500rpm, 0.8bar by 4000rpm....
does that sound normal?
does the actuator setting have anything to do with how fast it boosts? or is it just the max amount of boost?
any advice on what boost at wat rpm people get would be fantastic ;)
Well my car starts building boost strightaway I'm at 5psi by 1400rpm and 1bar by 2700-2800rpm but before I had my timing belt done my car was finding it hard to spool up quick. We found the problem was the timing was out by 1 tooth on the cam belt now I'm not saying you have the same problem but it could be something to get checked.
had a play today n sorted it!
Actuator position is the problem...
it seems to get it to be at 1bar at 2800rpm, the max boost is 1.2bar....
so a boost controller is needed now lol!
