dobbs Posted May 6, 2010 Posted May 6, 2010 hello everyone :harhar:hope someone can help.im trying to find a 1/8bsp male - m10 female adapter to fit my autoguage oil temp sender. all i can find are 1/8nsp to M10?any suggestions?cheers Quote
jason_l Posted May 6, 2010 Posted May 6, 2010 these are also worth a try......http://www.merlinmotorsport.co.uk/https://www.europaspares.com/http://www.cbsonline.co.uk/Jason :harhar: Quote
WallaceGlanza Posted May 6, 2010 Posted May 6, 2010 http://www.demon-tweeks.co.uk/Motorsport/G...Piece/1773/1861Only thing is you'll need to block off one outlet and it advises that it's not the best for oil temp senders, I use one of them for the oil pressure though.Or one of these....http://www.demon-tweeks.co.uk/Motorsport/G...ptors/1773/1847But use a 1/8npt for the male as bsp and npt in that size is basically the same thread. Quote
Lee_EP82 Posted May 6, 2010 Posted May 6, 2010 http://www.demon-tweeks.co.uk/Motorsport/G...Piece/1773/1861Only thing is you'll need to block off one outlet and it advises that it's not the best for oil temp senders, I use one of them for the oil pressure though.Or one of these....http://www.demon-tweeks.co.uk/Motorsport/G...ptors/1773/1847But use a 1/8npt for the male as bsp and npt in that size is basically the same thread.Mate you know the top link.What do i choose for engine thread and take off thread? Quote
dobbs Posted May 6, 2010 Author Posted May 6, 2010 http://www.demon-tweeks.co.uk/Motorsport/G...Piece/1773/1861Only thing is you'll need to block off one outlet and it advises that it's not the best for oil temp senders, I use one of them for the oil pressure though.Or one of these....http://www.demon-tweeks.co.uk/Motorsport/G...ptors/1773/1847But use a 1/8npt for the male as bsp and npt in that size is basically the same thread.aaahhhhhhhhh winner!!! cheers mate! i did wonder if they were the same?that makes it so much easier lol.thanks again!! :harhar: :lol: Quote
WallaceGlanza Posted May 7, 2010 Posted May 7, 2010 Mate you know the top link.What do i choose for engine thread and take off thread?I think it is the 1/8bsp you want for the engine thread and hence standard oil temp switch, however I have 1/8npt on mine and it does fit but becuase the engine thread isn't tapered it doesnt fully engage but doesn't leak either. Quote
silverglanza Posted May 7, 2010 Posted May 7, 2010 how do u actully install a oil pressure gauge ? where to do u plum in to?pics Quote
gary_yuen42 Posted May 17, 2010 Posted May 17, 2010 how do u actully install a oil pressure gauge ? where to do u plum in to?picsYou can get a sandwich plate, goes between the block and the oil filter. They will have holes drilled and tapped ready for the sensor. I got one surplus if you need it let me know :harhar: thanks Quote
