wssoR Posted May 10, 2010 Posted May 10, 2010 I take it i have to take the interior lining of the boot off, but its got these crummy little plastic screws in, are these the ones that you have to replace when you remove them because they dont unscrew and i guess you have to force them out?Cheers Quote
Ryan Milne Posted May 10, 2010 Posted May 10, 2010 I take it i have to take the interior lining of the boot off, but its got these crummy little plastic screws in, are these the ones that you have to replace when you remove them because they dont unscrew and i guess you have to force them out?CheersIf they are the same as in my Glanza then no you don't have to replace them. You should just use a small pick to lift the centre circle bit up and the screw should pop out. Quote
Raz Posted May 10, 2010 Posted May 10, 2010 one of my number plate lights blew out. so i had to take them off aswell, I just propped them out with a screw driver and then you will understand how to re-use them Quote
Russleh Posted May 10, 2010 Posted May 10, 2010 use a stanley knife to pop the centres out. thats what i did as with a screw driver ya end up juat squashin them where ae ya gonna get a little bung for the hole from ? i bought one from 200sxjay off here because he done his but it didnt fit mine and im stuck where to get them. once the linings off its just 3 10mm bolts Quote
wssoR Posted May 10, 2010 Author Posted May 10, 2010 ok cheers guys@russleh, im gonna buy a pack of grommets from halfords with all diffrent sizes in as im not sure exactly what size the hole left is. Quote
LukeSR Posted May 10, 2010 Posted May 10, 2010 Just took the interior lining of myself not long ago, gunna go to halfrauds tomorrow and get some bungs Quote
Russleh Posted May 10, 2010 Posted May 10, 2010 sweet didnt know halfrauds sold bungs. ill be taking my wiper off then Quote
wssoR Posted May 10, 2010 Author Posted May 10, 2010 Just been out and took it off now, such a simple mod and yet so effective, really smartens the back end up. gonna get some paint and spray the bung so it matches the car Quote
Raz Posted May 10, 2010 Posted May 10, 2010 thats tempting if you can get the bung from halfords. which size did you end up getting? Quote
