De Wipering Rear Window?
I take it i have to take the interior lining of the boot off, but its got these crummy little plastic screws in, are these the ones that you have to replace when you remove them because they dont unscrew and i guess you have to force them out?
Cheers
Cheers
If they are the same as in my Glanza then no you don't have to replace them.
You should just use a small pick to lift the centre circle bit up and the screw should pop out.
one of my number plate lights blew out. so i had to take them off aswell, I just propped them out with a screw driver and then you will understand how to re-use them
use a stanley knife to pop the centres out. thats what i did as with a screw driver ya end up juat squashin them :rolleyes:
where ae ya gonna get a little bung for the hole from ? i bought one from 200sxjay off here because he done his but it didnt fit mine and im stuck where to get them.
once the linings off its just 3 10mm bolts
Just been out and took it off now, such a simple mod and yet so effective, really smartens the back end up. gonna get some paint and spray the bung so it matches the car :rolleyes:
