BoostJunkie Posted October 19, 2006 Posted October 19, 2006 I need some help folks me and my friend at work tried to change the rear brake pads on my ep82 gt and the piston would not push back and we couldn't get the new pads in as a result , or could we get the original gubbed ones back in so we had to stick the one that was ok back in at the back of the disc and put the caliper back on so i could get home but on the way home discovered that the hand brake light is stayin on only comin off when i accelerate how is this and how do i get the piston back in HELP PLEASE . Quote
ian Posted October 19, 2006 Posted October 19, 2006 i use a g clamp to put the piston back inwith regards to the handbrake light got no idea weird one Quote
Blue Icarian Wings Posted October 19, 2006 Posted October 19, 2006 If the rear brake is palying silly buggers it could making the sensor play up Quote
BoostJunkie Posted October 19, 2006 Author Posted October 19, 2006 i use a g clamp to put the piston back inwith regards to the handbrake light got no idea weird onetried using a g clamp couldn't get it positioned properly,with me only placing the one pad back in could that be the reason the hand brake light is still on. because i think the hand brake may be stuck on now. dont know my brothers the mechanic get him to look at it tomorrow cheers anyway guys appreciated Quote
SiCaln Posted October 20, 2006 Posted October 20, 2006 yea the rear discs dont just push in they twist, try using the end of a spanner in the grooves Quote
