Forged Internals
hi guys, going to be building a forged engine up over winter!
what would you recommend, whats the strongest?
wiesco or wossner or JE pistons
scat or pauter or PEC Rods...
which brand metal headgasket, and what thickness?
likin the look of wepr's godzilla or a td05-6 conversion....
any info wud be brilliant :lol:
Cheers
Matt.
I use wiseco's - they are the best
as for rods - pauter ones do not require the block to be knotched and scat ones do require it
athena,zep,cruise headgasket if you want a td06 you' more than likely want quite a thick one - possibly 2mm ??
A list of things TM do for there engine forge
All engines stripped and thoroughly chemically cleaned.
Block rebored,
crosshatch honed.
Forged low comp pistons, 74.5/75mm,
forged rods.
Crank reground (if needed) with all new bearings.
Head stripped and cleaned,
valves re seated,
new valve stem seals,
New Head Bolts.
New Toyota oil pump,
new water pump,
new cam belt and tensioner kit,
new oil sender switch,
new thermostat.
All new gaskets and oil seals.
Metal head gasket 1.2/2mm
I know you might already know this but its useful for anyone reading this section who doesnt.
As for makes id deffo say wiseco and wossner are good for rods and pistons, maybe a ZEP of TRD headgasket, cruise are good for the valve springs and a lovely set of TRD mounts to hang them on :lol:
For new gaskets oil/water pump etc get them from toyota B) cant wait to see you do this mate deffo go with the godzilla kit :lol:
To add; I cannot really speak on personal experience or practical evaluation but I have heard/read enough to make some quasi-educated judgements! Basically;
- Pistons -
- JE are one of the top manufacturers for pistons in America, great quality items
- CPP another high-end manufacturer, recently joined forces with Carrillo, and their conglomeration even supplies to F1, amongst other high prestige motorsports
- Wossner, not heard much, but they are relatively new company seemingly
- Ross are very cheap, but I've heard a lot of accounts of their piston rings being far too hard and greatly accelerate bore-wear
- Connecting Rods -
- Carrillo are one of the top manufacturers of rods, but also priced as such, don't need notching
- SCAT, very cheap and economical, need notching
- Pauter are another popular company
- PEC have had some quality issues in the past
For your setup, were you going for a 5E base? You have to make consideration of what you're looking for out of your setup as well - do want a responsive and tractable setup, or something that can take a lot of boost? The importance is to decide precisely what you want out of your setup, before selecting parts.
