andieep82 Posted May 13, 2010 Share Posted May 13, 2010 Ok so i have just got a braided oil return but it is leaking at the flange, i am thinking of using a small bit of gasket sealent to seal it properly but am not sure if this is a good or bad idea as i have had mixed comments, someone said use cork gasket but i no the oil eats away at it??? please help as need to fix this problem.... Quote Link to post Share on other sites
ollie ryan Posted May 13, 2010 Share Posted May 13, 2010 had the same problem with mine and was told to use sealant by ricky but havnt had a change to fit it again yet Quote Link to post Share on other sites
Russleh Posted May 13, 2010 Share Posted May 13, 2010 cant see a bit of sealant doin any harm as long as ya dont got crazy with it. Quote Link to post Share on other sites
andieep82 Posted May 13, 2010 Author Share Posted May 13, 2010 ok great i will give it ago then because was unsure wheither if a bit of sealent went into the oil feed if it would clog it up and cause problems?? Quote Link to post Share on other sites
WallaceGlanza Posted May 13, 2010 Share Posted May 13, 2010 andieep82 said: ok great i will give it ago then because was unsure wheither if a bit of sealent went into the oil feed if it would clog it up and cause problems??Yes it could kill the turbo.Have you got any copper washers on there? Quote Link to post Share on other sites
Russleh Posted May 13, 2010 Share Posted May 13, 2010 if you only use like a slight spread of it to cover any uneven bits the bits if any that would go inside would be minimal. i think he means the bit thats kinda diamond shaped. cant put copper washers on that. Quote Link to post Share on other sites
keirz Posted May 13, 2010 Share Posted May 13, 2010 i wouldnt. cant you just change the gasket? Quote Link to post Share on other sites
WallaceGlanza Posted May 13, 2010 Share Posted May 13, 2010 Russleh said: if you only use like a slight spread of it to cover any uneven bits the bits if any that would go inside would be minimal. i think he means the bit thats kinda diamond shaped. cant put copper washers on that.It is a minimal chance that a bit would come off and blockanything but when there's that chance it's something I wouldn't risk.If it is at the turbo where it's leaking then a new gasket should sort it. Quote Link to post Share on other sites
Russleh Posted May 13, 2010 Share Posted May 13, 2010 i was just about to say does that bit not have a gasket anyway. . see when ya get a full gasket set does it include all the wee daft ones like that ? Quote Link to post Share on other sites
