Right in the process of fitting the rolla mani to my n/a..
Where have people put there throttle cable wire to? Like bolted it to what? There was a bracket that connected to the old inlet mani but not on the rolla, need some help sharpish please!!
i made a new bracket on mine. like two u shaped flat bit of metal and they were clamped with the nuts on the cable. before i made them though i just used the rolla mount n used the nuts on the cable. from memory. sorry if its wrong.
I can't remember exactly what I did with mine but I know I re-used the old rubber thing and just adjusted the cable holder on the two nuts and it worked fine. If the metal U shape thing on the manifold doesn't grip the rubber thingy then smack it with a hammer, then you can put the cable into it and it will hold.
That probably doesn't make any sense whatsoever but you don't NEED to make up a new bracket or anything you can use what's already there.
Well me dad has bodged the job for now :p
Got it all on and running smoothly, love the sound if it :p
Cheers for the replies!
You running an open filter or standard airbox?
With the airbox I noticed a slight change of pitch at higher revs but still quiet.
When I changed the airfilter I loved the sound of it, especially between 4k and redline. The standard manifold doesn't sound as good IMO.
Open filter mate, love it :p
