el_man Posted May 21, 2010 Posted May 21, 2010 my mate has a set of wheels for sale off his nova his are et35 and mine are et40 we put his one and it fitted but they are soooo close to the coilover does the et35 n et40 pretty much mean 5mm? i dont really know all this stuff will a spacer sort it out? reason why im buying them is because they have r888s on them and they are my track wheels Quote
Lukew360 Posted May 21, 2010 Posted May 21, 2010 Yep offset is measured in "mm", I would say yes a 5mm spacer would bring the wheel out far enough. Would bring it inline with a wheel of a ET40 Offset.oh are they 6.5inches wide or 7inches? Quote
el_man Posted May 21, 2010 Author Posted May 21, 2010 Yep offset is measured in "mm", I would say yes a 5mm spacer would bring the wheel out far enough. Would bring it inline with a wheel of a ET40 Offset.oh are they 6.5inches wide or 7inches?ermmmm no idea lol 195 tyres on it all fitted just close to the coillie Quote
Lukew360 Posted May 21, 2010 Posted May 21, 2010 you can fit 195 tyres on a 6.5" or a 7" wheel! Quote
el_man Posted May 21, 2010 Author Posted May 21, 2010 haha them i have no idea i`ll try find out but should i go for 5mm spacers? anyt they should all bolt up nicely? Quote
Lukew360 Posted May 21, 2010 Posted May 21, 2010 My personal opinion mate is "YES" a 5mm spacer and it will be fine.Although a second confirmation is welcome!hint hint people Quote
anup67 Posted May 21, 2010 Posted May 21, 2010 As far as I no yh 5mm is enough to do it up with standard nutsIf you were getting 10mm then you will have to get longer bolts/ (well what you screw the nut onto) on the hub Anup Quote
Russleh Posted May 21, 2010 Posted May 21, 2010 well how close are your normal wheels to the coilovers if a 5mm spacer takes it to about the same as that then it should be fine just dont have the wheels sticking out the arches ( not that 5mm would do that ) not as if the wheel has much movement towards the coilovers so should be ok imo Quote
LukeSR Posted May 21, 2010 Posted May 21, 2010 I have 5mm spacers on the front of my SR, plenty of thread left... I'd say 6-7mm at the most Quote
Turkish91 Posted June 6, 2010 Posted June 6, 2010 I have 5mm spacers on the front of my SR, plenty of thread left... I'd say 6-7mm at the most With the Speedlines? Quote
yaristurbo Posted June 6, 2010 Posted June 6, 2010 if you go with the 5mm spacer just make sure there plenty of avaible threads left for the wheels nuts Quote
