can i use the standard banjo bolt that goes near the oil filter housing into my td04 oil line ?
and is it a m14 x 1.5mm bolt?
It depends if the oil line is the same size as the old standard one, usually it should be ok but just match up the pipe ends to see if they are the same and try the bolt in the pipe and join it to the oil filter housing to see if it will all seal up
And i would recommend a fresh banjo bolt washer which will be available from Toyota if the pipes are the same.
Gary
If it's the end that goes onto the filter housing it can only be one size, otherwise it won't fit the filter housing. If the td04 + line were originally fitted on an EP you won't have any problems.
