rapidep Posted June 3, 2010 Share Posted June 3, 2010 I have a 97 Glanza with some unknown make of suspension on it and everytime I am driving when I lift of the accelerator I get a knock from the drivers front wheel. I have had the wheel off, tightened the hub nut, checked for play, bang the caliper to make sure the pads arent moving and I still cant find itIt sounds a bit like the driveshaft is knocking when I come off the accelerator but I dont know if that is possible? It does not knock with suspension movement only when coming off the acceleratorAny help or ideas will be greatly appreciated as its started to do my head it now! Quote Link to post Share on other sites
ste91 Posted June 3, 2010 Share Posted June 3, 2010 You sure it's not the engine mount knocking? There will be a bit of movement in the engine if suddenly letting off the throttle, and there's an engine mount on the driver's side. Quote Link to post Share on other sites
rapidep Posted June 3, 2010 Author Share Posted June 3, 2010 ste91 said: You sure it's not the engine mount knocking? There will be a bit of movement in the engine if suddenly letting off the throttle, and there's an engine mount on the driver's side.Hmm I havent checked the engine mount but it really does not sound like that sort of knock, it sounds low down at the wheel. I will definately give it a look at though as im doing the cambelt saturday. Just annoying noise that I cant find Quote Link to post Share on other sites
ste91 Posted June 3, 2010 Share Posted June 3, 2010 A mate had the exact same problem on her 106 and it sounded like you described - as if it was coming from the wheel, she even replaced the driveshafts and it was still there, later to be found out it was the engine mount. Quote Link to post Share on other sites
rapidep Posted June 3, 2010 Author Share Posted June 3, 2010 ste91 said: A mate had the exact same problem on her 106 and it sounded like you described - as if it was coming from the wheel, she even replaced the driveshafts and it was still there, later to be found out it was the engine mount.Ok thanks for the advice mate, I'll check it Saturday when I do the cambelt and fingers crossed its fooked Quote Link to post Share on other sites
rapidep Posted June 5, 2010 Author Share Posted June 5, 2010 Nice one ste! Took the mount off when doing the cambelt and it near enough fell apart in my hands, now at least thats sorted! Quote Link to post Share on other sites
