ollie ryan Posted June 5, 2010 Share Posted June 5, 2010 right my car has oil everywhere in the engine bay, its all over the rocker cover and it seems to be coming out of the dumpvalve spraying on the inside of the bonnet and its also coming out tof the breather.had the head gasket done bout 6weeks ago so is it the oil seals on the turbo?seriously had enough with my car tempted to break it and get something else or ep95 now. the car has covered just over 144,500kmthanks in advance for the help Quote Link to post Share on other sites
scot-ish Posted June 5, 2010 Share Posted June 5, 2010 answered your own question mate, oil seals Quote Link to post Share on other sites
Ryan-11 Posted June 5, 2010 Share Posted June 5, 2010 get a compression test done, mines done this ( oil out the dumpy and breather ) it turned out to be piston/piston ring damage Quote Link to post Share on other sites
ollie ryan Posted June 5, 2010 Author Share Posted June 5, 2010 thats alright then just hoping it wasnt piston rings lolcheers mateah fuckif its piston ring then i cant be arsed to get the thing fixed anymore Quote Link to post Share on other sites
Sparky Posted June 5, 2010 Share Posted June 5, 2010 Deffo sounds like ringland, piston failure.Should of got the place to check the rings while the head was off Quote Link to post Share on other sites
ollie ryan Posted June 5, 2010 Author Share Posted June 5, 2010 ah fuck itthink it will be another glanza going to the breakers yard Quote Link to post Share on other sites
scot-ish Posted June 5, 2010 Share Posted June 5, 2010 i would have thought the rings would have been checked when the HG was done, after all, how did you diagnose the HG problem, compression test, so surely there would have been a compression test done once the new HG was fitted? Quote Link to post Share on other sites
scot-ish Posted June 5, 2010 Share Posted June 5, 2010 Deffo sounds like ringland, piston failure.Should of got the place to check the rings while the head was offhow do you test the rings with the head off? Quote Link to post Share on other sites
ollie ryan Posted June 5, 2010 Author Share Posted June 5, 2010 cars going to get a compression test at 4todayhow much would it cost to repair or is it easier to just get a new engine? Quote Link to post Share on other sites
Sparky Posted June 5, 2010 Share Posted June 5, 2010 Usually if theres excessive play when you move the piston about you could tell Quote Link to post Share on other sites
ollie ryan Posted June 5, 2010 Author Share Posted June 5, 2010 buit if it was a piston ring would it not loose boost or have a loose in performance? Quote Link to post Share on other sites
Russleh Posted June 5, 2010 Share Posted June 5, 2010 just a heads up tho mate when my ringland and ring were gone a compression test still didnt show it. showed that one cylinder was a couple psi lower and that was it so dont always relly on the compression test.also my car felt fine performance wise. Quote Link to post Share on other sites
ollie ryan Posted June 5, 2010 Author Share Posted June 5, 2010 how did you find out yours had gone then mate? Quote Link to post Share on other sites
Sparky Posted June 5, 2010 Share Posted June 5, 2010 mine really did loose performance but I was driving it for a while lol Quote Link to post Share on other sites
Russleh Posted June 5, 2010 Share Posted June 5, 2010 show people some pics of the oil comin out and stuff then trusted there diagnosis and build another bottom end and swapped them over one day. took 2 pistons out and started to doubt it but the 3rd one was in bits Quote Link to post Share on other sites
ollie ryan Posted June 5, 2010 Author Share Posted June 5, 2010 well mine is getting through shit loads of oil so i dont want to risk driving it anymore and i have no job to pay to repair now Quote Link to post Share on other sites
Blitz Posted June 5, 2010 Share Posted June 5, 2010 feel for you dude as have you noticed i put up a thread today just like yours Quote Link to post Share on other sites
ollie ryan Posted June 5, 2010 Author Share Posted June 5, 2010 yeah i just saw it matefucking shit timing ayetwo white Vs sick as a dog Quote Link to post Share on other sites
Russleh Posted June 5, 2010 Share Posted June 5, 2010 that sucks man. always happens at the worst time Quote Link to post Share on other sites
scot-ish Posted June 5, 2010 Share Posted June 5, 2010 show people some pics of the oil comin out and stuff then trusted there diagnosis and build another bottom end and swapped them over one day. took 2 pistons out and started to doubt it but the 3rd one was in bitssorry mate, but i dont believe if a piston came out with damaged ringlands, that there was no obvious notice in compression test. i would bet that a comp test will show ringlands everytime. especially since yours came out in "bits".sparky, surely the rings would have to be lyin in the sump before you would notice play in the pistons? and even if the ringlands had gone, the ring would still be the part holding the force against the liner. i dont see how you can test ringlands or rings, other than via a compression test, or pulling the pistons out.to the poster--if you have ringland failure, and your loosing that much oil, you will notice a loss in performance.do a compression test, that will tell you if its your block, or if its your turbo seal, your wouldnt notice much of a difference in performance if the seals had started going, but oil would still pass. Quote Link to post Share on other sites
Sparky Posted June 5, 2010 Share Posted June 5, 2010 Im not on about mine mate, mine hasnt been apart yetMy mate has a Williams engined clio valver which smoked like a right cunt so done the stem seals and while the head was off we checked for play in the pistons and there was "excessive" play but he chose to ignore it and it still smokes like a cunt. Quote Link to post Share on other sites
Russleh Posted June 5, 2010 Share Posted June 5, 2010 im not arguing mate but i stood there while i had a compression test done and i cant remember what it showed but across all 4 there wasnt much difference and when i took my piston out it looked like this and i cant rmember who it was i think it was rory ( dont quote me on that ) that said ringlands dont allways show up in a compression test Quote Link to post Share on other sites
scot-ish Posted June 5, 2010 Share Posted June 5, 2010 maybe one ringland with a small crack might not show a massive difference, but ringlands failed, more than one, i would guarantee it will show down on compression,which ring is it in your pic? i cant tell from it being fuzzy, and did only one come out like that. what youve pictured would show a drop in compression. Quote Link to post Share on other sites
ollie ryan Posted June 5, 2010 Author Share Posted June 5, 2010 so im getting a compression test done in half hour willl post the results up whats the best optiion for me to do if it is piston or ring failure?cheers Quote Link to post Share on other sites
Danturbo4311 Posted June 5, 2010 Share Posted June 5, 2010 If they do a compression test & any cylinders are low put a teaspoon of oil down them, then re-test it, if it raises compression then you will no for sure its piston problem (cracked ringland). Out of interest what was up with your last headgasket (did it blow between cylinders or between oil & water gallery). Also did they set up your ignition timing correctly at 10degrees with a timing light after they did the headgasket.The only options you got if it is pistons is, take the head back off & replace the pistons, or go forged, or buy another engine. Quote Link to post Share on other sites
