yaristurbo Posted June 8, 2010 Posted June 8, 2010 hi guys, the yaris is coming on good now, 2.5 inch staright through, motec, fmic, 235lph fuel pump, trd thermostat, . but im wanting to forge and big power time. what dealers do you recommend and prices on the forges, and what turbo! there are so many to go at min, just not sure what to do, prices on that needed also lolthanks dantd012???? Quote
Sanchez Posted June 9, 2010 Posted June 9, 2010 As Steve said, have you the 4EFTE engine transplant in your Yaris dude?Unless your handy at building engine mate? then i would go with one of the site traders, PP, TMD or TD, all have built up forged engines, and you will get some sort of warrenty if you go with a trader i think?Your looking at around 2K, obviously depending on spec you want. You wont save much that much money i dont think if you buy all the parts seperate, and get the machine work done, and then assembled.TD12 is what you mean i think? I would go for something a little bigger on a forged engine if it were me. Quote
Steve GT Posted June 9, 2010 Posted June 9, 2010 td05 with a forge but you will need to get the pennies out gaz from pp is selling one check the for sale section Quote
Socks Posted June 9, 2010 Posted June 9, 2010 td05 with a forge but you will need to get the pennies out gaz from pp is selling one check the for sale sectiontotally depends on the room in the bay, as a td05 isnt a small setup...if room is tight mate go with a ct12 there capable of 200horses at less then 1bar. Quote
yaristurbo Posted June 9, 2010 Author Posted June 9, 2010 yeh mate its in the yaris, what sort of power will i get out of the ct12 if i dont forge Quote
Guest Enzo Posted June 9, 2010 Posted June 9, 2010 hey dude there are two flavours of the newest version of td12 both desinged to be used with out the hastle of forging.have you seen the td12 section in the tuner store?a lower lag model for 220bhp and a larger ar model for 245bhp. both should comfortably achieve these goals at 1.2 -1.3bar.we currently have two people testing the smaller version and nead someone to test the bigger model.any takers? Quote
Steve GT Posted June 9, 2010 Posted June 9, 2010 totally depends on the room in the bay, as a td05 isnt a small setup...if room is tight mate go with a ct12 there capable of 200horses at less then 1bar.ct12 never heared of that before matt you mean the td12 haha Quote
