Hey guys
Just wondering if anyone knows what's the best offset to get a bit of USDM style poke on an EP91?
Would you need lower offset wheels for a 6.5" wide rim than 7"?
Looking for this kinda fitment:
S2000
S14
Accord
Stance!
Or if I just wanted to get that fitment on my current (I think) 7" wide wheels, can anyone link me to a big spacer kit? Currently got 3mm, 5mm spacers
Thanks!
Amjad
its called 'hella flush' :) and looks quality on the right car, but expect to have a short tyre life span as ure arches frequently burn a line into them
I have 15x7 ET7 wheels which are just short of being flush of the arches, so ideally for the car to be "hella flush" you'd need ET0-ET5 wheels. And they'll rub. On a 6.5" wheel you'll need an even more aggressive offset
the problem with huge spacers on an EP is that ideally u need ones with bolts on them, same as spuddy runs at the draggin, otherwise u could drastically shorten the number of threads your wheel is secured by.
Phil.
Yeah I didn't wanna go with more than 5mm at the moment, just for peace of mind that the wheels are help on securely!
its called 'hella flush' :( and looks quality on the right car, but expect to have a short tyre life span as ure arches frequently burn a line into them
That's the one! I always forget what it's called lol
I wouldn't have it as drastic as that as my car is only dropped 40mm, but I want a bit of a wider stance you know?
Wow I wasn't expecting to need such a low offset! :D
you'll need hubcentric spacers...cant beat camber and tyre stretch :D
:lol:
Does any one know how much a set of Hubcentric spacers would set me back, and how hard are they to fit? I wish EPs just needed longer bolts for spacers :D
Thanks for the help guys!
I think dean jdmep91 is running et0 on 8" rims but thats beyond hella flush :lol: u gotta do it Am, will look awsome, and get some coilys to tuck the tyre :(
I think dean jdmep91 is running et0 on 8" rims but thats beyond hella flush :( u gotta do it Am, will look awsome, and get some coilys to tuck the tyre :D
I really want it man! And don't worry I WILL be buying Meisters in the future. I'll definitely be running them on my future GT/Glanza, hopefully I'll be able to get them while I still drive the N/A
you can buy hub kits from www.wheels.uk.com they are about £120 a set.ive got 20mm ones on the back and need a set for the fronts aswell
Nice one Matt! I'll need to look into them!
Thanks for all your input guys! :lol:
yup as above you will need some burly man offsets... like ET0 on a 6.5-7 or possible a ET10 or so on a 7.5-8
I would say get a 7" wide wheel around the ET10 mark and space it out (after rolling your arches) :lol:... my mr2 had ET38 with a 20mm spacer and that was flush as! had to roll the arches as they rubbed :(
  • 2 weeks later...
I'm flogging a set of 15's that would have been pefect (I've blasted them to bare metal as well).....but are 4x108!!!!!!!!! :):D:D
Get this, staggered 3-peice split Compomotives, 15x10 ET-22 rear / 15x8 ET-12 front....NEGATIVE offset FTW!
I want to keep them but I'm too much of a hoarder!!! :)
Keri, I would rock those. Give you a hug for them? I'll just use PCD convertors, so they're ET-2million, will be fine :)
  • 2 weeks later...
Seen this GT and thought of this thread,
This GT has 16" X 8" Rota Grids in Bronze.......(Droool)
Has a nice stance, think these might be my next wheels :)
(Also this picture is my Wallpaper)
  • 2 weeks later...
Still tring to figure out you're plan Amjad.... USDM?....
by the way that gold EP82 has Rota Grids 16" x 8" with 10mm spacers. quite an awesome stance.
