just bolt it on and pipe a vac line from the actuator to the turbo, who needs low boost anyway lol.
and as wallace stated 0.8bar mate, you cant go anymore due to fuel cut. shouldn't take any longer then 30mins to fit
You've got the wrong type of actuator arm you need the pin type for a glanza.
However you can use a bolt as long as it's a slightly loose fit (there arm pivots around the pin slightly so too tight and it won't move) or get a pin with a circlip either end.
