stan_the_man Posted November 3, 2006 Posted November 3, 2006 is it possible to raise the rev limiter on a 4E-FE??if so, how??cheers Quote
scutch0 Posted November 7, 2006 Posted November 7, 2006 you cant remap the standard ecu, and i dont think there is a chip available.the only easy way you can do it is the way i was gonna do my 4efe, i had bought a jdm ecu for the starlet (jap spec, which rev to 7200) and tried that, but the wiring was slightly different, so i needed to get it rewired. i never got round to it though.other than that you could try a corrolla 4efe ecu and see if you can get that to work, im sure they have a higher limit. Quote
stan_the_man Posted November 7, 2006 Author Posted November 7, 2006 other than that you could try a corrolla 4efe ecu and see if you can get that to work, im sure they have a higher limit.Is this possible?i work ata breakers yard so i can get one of these no problem Quote
scutch0 Posted November 7, 2006 Posted November 7, 2006 i have one at home too... again i bought it for my old 4efe it didnt work when it was just plugged in, it'd probably need rewiring. i'd check to make sure the engine you get it from has the same injectors and stuff though. Quote
Glanza_Ragger Posted November 7, 2006 Posted November 7, 2006 superchip can chip and tune your standard ecu.allthough for the price of it you may as well get a piggy back or even a little extra and get a apexi pfcecu is the way forward mate. Quote
ecksjay Posted November 7, 2006 Posted November 7, 2006 .....or get a 4efte. you wont get much/any benefit from just raising the rev limit, because peak torque is probably achieved at FAR less than the redline anyway, prob around 5krpm, so revving in any higher would actually be slowing you down anyway. Quote
Guest Enzo Posted November 7, 2006 Posted November 7, 2006 did you actualy own a 4efe eky boy, with those inlet manifolds you find yourself runnin out of revs in the first three gears pretty easily, the limiter is at 6.2k which is gashthere was a mod a while back posted on a paseo site about changing the resistance of one of the quatzs crystel within the ecu but i would not know what rating it would be for a 7.5k redline, would definatly be a bonus, any higher tho and ull start getting vavle slap as the tolerence of the valve springs were not really designed to take any more.msd make little black boxes for revlimiters, the same with b-r too which dont cost nearly as much as an ecu and limit the spark instead of leaning hte petrol giving a nice flame effect lol Quote
ecksjay Posted November 8, 2006 Posted November 8, 2006 running out of revs, yes, but that doesn't mean you're getting ANY more power, im sure if you look at the peak power graph you'll find its achieved far less than the rev limit, meaning, if you change gear earlier, you'll be within the power band more and as such theoretically be quicker, if you just keep revving and revving the power will be tailing off and you wont actually be gaining anything, most likely you'll be slower.I've never OWNED a 4efe myself no mate, but that theory is pretty generic throughout all n/a engines, bar a select few ofcourse. Quote
Nanglebadger Posted November 8, 2006 Posted November 8, 2006 Hmmmm this is interesting me as mine should be fitted on friday.Phil. Quote
Guest Enzo Posted November 8, 2006 Posted November 8, 2006 you actualy drop out of the power band inthe first two gears dude Quote
Nanglebadger Posted November 8, 2006 Posted November 8, 2006 ^^^ is that directed at me or eks mate??So is there anything else i should be addin after the mani is fitted in order to get the most from it or not then?? all this talk of ecu's etc etc has lost me. saome say yay, some say nay! wots the final verdict?Phil. Quote
Guest Enzo Posted November 8, 2006 Posted November 8, 2006 that was directed at ecks, depends if you like kainin the shit ou of your car phil, ull find once you fit hte mani in th efirst couple of gears ull be hitting the limiter if your not paying full atention,do a search online for a company called msd, they make revlimiters and if you really wanted to make the most of it get some fhe cams, they only contain slightly more lift in the duration but every little helps Quote
Nanglebadger Posted November 8, 2006 Posted November 8, 2006 fhe cams eh??Wot all would be involved in fittin these then dude and would they make a differnce really? Would u recommend them for folk who have fitted the mani??Phil. Quote
whitestarlet Posted November 8, 2006 Posted November 8, 2006 i would have a guess at stripping most the of head down phil, re shimming the valves for clearance, replaceing the cams. basically letting more air in and out though im not sure jus how much of a difference. Quote
massen1981 Posted September 12, 2008 Posted September 12, 2008 get an emanage ultimate, and start tuning Quote
Guest Enzo Posted September 13, 2008 Posted September 13, 2008 that would require quite a large outlay, Quote
