glanzap88 Posted July 11, 2010 Posted July 11, 2010 my car failed mot with abs light, anyone had this and how u get around it, cheers!! Quote
Sanchez Posted July 11, 2010 Posted July 11, 2010 Have you removed the fuse for the abs?You take take the fuse out to stop the abs working i beleive, my mates gt had his removed by previous owner when he was track racing, and i think the light is on. Quote
DavidAshton Posted July 11, 2010 Posted July 11, 2010 Take the bulb out, quick and easy fix for the purpose of passing an MOT. Quote
glanzap88 Posted July 11, 2010 Author Posted July 11, 2010 cheers, yh jus need a quick solution for the min thn look into it properly after that. ta Quote
rorenapier Posted July 11, 2010 Posted July 11, 2010 The ABS light has to come on with the ignition and off when the car starts to pass an MOT.Why is your ABS light on? Quote
Lee_EP82 Posted July 11, 2010 Posted July 11, 2010 Yep ABS light has to come on then go off after so many seconds.Find out why its on maybe a sensor is buggered, not sure on how you test them as mine hasn't got ABS as i guess you do a diagnostics check withese unless you can do a check from ABS unit. Quote
glanzap88 Posted July 11, 2010 Author Posted July 11, 2010 ow rit, ummmm well av to av look, how u do dianostic???what cus the promblems be to check thm off if anyone knows??ta Quote
ToyotaTech15 Posted July 11, 2010 Posted July 11, 2010 Can you please write in full words and not text speak as its easier for people to help you outCheersGary Quote
glanzap88 Posted July 11, 2010 Author Posted July 11, 2010 yeh no worrys just habit buddyhow you do dianostic for abs???what could the problems be? so can check them off one by one???ta Quote
ToyotaTech15 Posted July 11, 2010 Posted July 11, 2010 To carry out a diagnostic check, there should be a small black box in the top right hand side of the engine bay with diagnostic written on it,Open it up and use a paper clip to bridge out pins TE1 and E1 going by the marked grid on the inside of the box lid.Then switch your ignition on and this will flash your warning lights on the dash.They will need to be counted to fugure out what number it corresponds to on the diagnostic code chart.You need to count the number of flashes there is before and pauses, for exampleFlash Flash Flash (1 second pause) Flash Flash (3second pause) then back to the 3 flashes again, this will equal code 32.It may be a bit hard to understand but there is help on here if you are stuck, or drop me a pm.As for causes it could be, individual sensors, pick up rings on the shafts abs uint itself or even a bad earth but it will need checked firstHope this helpsGary Quote
glanzap88 Posted July 11, 2010 Author Posted July 11, 2010 sweet mate!! cheers for your time, giving us a handwell give it ago 2moro Quote
