ep91starbo Posted July 15, 2010 Share Posted July 15, 2010 Hello, i just bought a 96 glanza V and when cold started the there is a ticking noise from the engine, the ticking noise isnt as loud after about 15 seconds or so.Im not to sure if its the idle control valve or it might be a cracked mani.heres a vid of the the engine bay when heated up. any advice if its a cracked head or mani or just the idle control valve would be appreciated , thanks. Quote Link to post Share on other sites
LukeSR Posted July 15, 2010 Share Posted July 15, 2010 Sounds like a belt to me? Quote Link to post Share on other sites
AlexGTAdv Posted July 15, 2010 Share Posted July 15, 2010 Its the idle control valve mate. They all do it. Will go crazy loud in the winter! Quote Link to post Share on other sites
ep_brad Posted July 15, 2010 Share Posted July 15, 2010 yep 100% its the idle control valve Quote Link to post Share on other sites
5T4R7ET N/A Posted July 15, 2010 Share Posted July 15, 2010 just out of interest what rpm is the car idling at??? Quote Link to post Share on other sites
ep91starbo Posted July 15, 2010 Author Share Posted July 15, 2010 just out of interest what rpm is the car idling at???On a cold start up around 1250 rpmwhen engine heats up a bit 750 rpm Quote Link to post Share on other sites
5T4R7ET N/A Posted July 15, 2010 Share Posted July 15, 2010 when the engine is warm and idling at 750 rpm, raise the rpm by 50 to 800 and see if it makes any difference to the noise. it is adjusted by a small screw located on the throttle body. to find it, follow the cable that attaches to the throttle body round on the linkage. the linkage piece rests on a little screw with a 8mm screw on the right. sometimes marked with a yellow dot. (sorry, not very good with explanations)i noticed that this reduced the noise from the ICV, but you will still be able to hear the injectors ticking away, they are pretty loud when bonnet is up. Quote Link to post Share on other sites
