nazzurro19 Posted July 16, 2010 Posted July 16, 2010 im not sure whether mines done up to tight or maybe its because its so new but everytime i go over a bump i can hear a "squeak" not sure why this is, is this common do other people have this ? Quote
Dave@TM-Developments.com Posted July 16, 2010 Posted July 16, 2010 Did you use the supplied grease? Quote
nazzurro19 Posted July 16, 2010 Author Posted July 16, 2010 ahh i dint get any grease , can i use cooper crease? i did put a lil copper grease in one of the bushes , maybe just not enough Quote
Asad Posted July 16, 2010 Posted July 16, 2010 My rarb does this, i used all the supplied grease when water gets to it it just dries out and starts making noise again havent found any grease that's waterproof. Quote
Dave@TM-Developments.com Posted July 16, 2010 Posted July 16, 2010 You need lithium based waterproof grease. nazzurro19 your inbox is full mate Quote
nazzurro19 Posted July 16, 2010 Author Posted July 16, 2010 yeah ill need a lil too that squeek sucks lol Quote
lukEp Posted July 16, 2010 Posted July 16, 2010 I never got any grease with mine so I just used normal stuff! Quote
Asad Posted July 16, 2010 Posted July 16, 2010 The original supplied stuff doesn't last long anyway Quote
Russleh Posted July 16, 2010 Posted July 16, 2010 make sure to use loctite on the big nut and check it every little while. i used threadlock on mine and it still came loose all the time and threads all all fucked now. Quote
JAG Posted July 17, 2010 Posted July 17, 2010 Mine does the same,I've tried so much crap on it like lock tight, copperslip, This plumbing tape stuff which is used to seal gas pipes (cant remember the name of it) but best thing is get it welded, just a spot weld on the nut where it meets the bar to hold it solid.I need to get mine done its started squeeking again.Pain in the ass £100 bit of metal wish id just kept the old one on... Quote
Asad Posted July 18, 2010 Posted July 18, 2010 is this what we need?http://cgi.ebay.co.uk/CRC-Super-Longterm-L...=item23030aadf2 Quote
nazzurro19 Posted July 19, 2010 Author Posted July 19, 2010 Maybe everyone has done them up so tight the rubber bush bit is being stressed , maybe if we literally do the bolt up just so it touches the rubber it wont squeek? Quote
