Josh@TunerLifestyle Posted July 31, 2010 Posted July 31, 2010 basicly this has been an ongoing problem since i fitted my fmic , every time i put my foot down and ii reach the third bar on the clocks there is a whisteling noise? to start with i thaught it was the intercooler piping not being tightend up but I've gone round all the pipes and there is no way it can be that,now i am looking at the turbo to hotpipe gasket and studs because they are short and i cant use washers so there is a small gap between the bolt,another question is where can i get that gasket from and also new studs as these ones have rounded out slightly and making it verry hard to tighten upcheers josh Quote
nazzurro19 Posted July 31, 2010 Posted July 31, 2010 could be a split mani i get a whistling noise when my mani is split then i get it welded it goes then it splits n comes bk lol Quote
Josh@TunerLifestyle Posted July 31, 2010 Author Posted July 31, 2010 I've got a a stock mani mate so i dout its split lol plus it looks allrite to me Quote
Josh@TunerLifestyle Posted July 31, 2010 Author Posted July 31, 2010 yes i have mate, I've checked for leacks tho nothing i can see Quote
Stulet-GTT Posted July 31, 2010 Posted July 31, 2010 yes i have mate, I've checked for leacks tho nothing i can seeHave you jus done this???I remember wen i relocated mine i had a whisteling noise that was not there befor, but it is jus the air being sucked in an causeing a whitle sound... Quote
Josh@TunerLifestyle Posted July 31, 2010 Author Posted July 31, 2010 noo I've had it done for about 3 weeks now but its gradualy got worse over the last week and I've had my intercooler about 2 weeksill have another look tommorrow but i do think its the hotpipe blowing as it dosent tighten up properly its hard to explane on here lol have to be in the car sorta thing Quote
DavidAshton Posted July 31, 2010 Posted July 31, 2010 I guarentee it will be a silicone pipe not tightened up properly. I had a leak for sooooooo long took ages to find. My advice would be to take your intercooler to bits and refit the pipes. Try the cold side, see if it goes, if not try the hot side. Quote
Josh@TunerLifestyle Posted August 1, 2010 Author Posted August 1, 2010 spose thers no harm in giving it a shot gotta get this hotpipe sorted first lol cheers guys Quote
birdmandan Posted August 1, 2010 Posted August 1, 2010 My turbo hotpipe was not tightening up properly as one of the bolts would not tighten up now as the thread on the bolt wasnt biting! This mad my car have a very annoying whistle/whining sound when i came on boooost! I bought a new mate bolt from B&Q and then stuck that and tightened up and have had no problems since so i would have said its most likely the turbo - Hotpipe leaking when on boost! Dan Quote
Josh@TunerLifestyle Posted August 1, 2010 Author Posted August 1, 2010 perfect description and exactly the same for me! sorted now:) cheers guys Quote
