Tomtheman2 Posted August 2, 2010 Posted August 2, 2010 I am very confused about what seats can fit in the ep91. Can these fit? I have a welder and stuff so is it a simple job to modify the rails to fit? If not, what seats fit in with little or no work?Thanks,edit http://cgi.ebay.co.uk/ws/eBayISAPI.dll?Vie...2#ht_500wt_1154 Quote
5T4R7ET N/A Posted August 3, 2010 Posted August 3, 2010 you can make most seats fit in a starlet with modification. as long as the seat will be able to fit in the car. remember you will need to still need to be able to slide the seat.What are " these seats" do you have a pic???i used the the starlet rail and cut the feet off, i found the starlet rail feet made the seat too high. the only reason i kept the starlet rails is so i can use the plastic trim on the side of the originals rails.some people just use the the rail of the new seat and weld or bolt new feet on, which is easier.good luck Quote
Tomtheman2 Posted August 3, 2010 Author Posted August 3, 2010 Ok I think I understand what your saying. These seats i was on about. http://cgi.ebay.co.uk/ws/eBayISAPI.dll?Vie...2#ht_500wt_1154Thanks, Quote
Pandamonium Posted August 3, 2010 Posted August 3, 2010 Yeah they will fit not a problem, you will be even be able to fit the armrest with them in.Check out nanglebadgers ep91 build thread Quote
Nanglebadger Posted August 3, 2010 Posted August 3, 2010 yip, been running them for around 5 years now.Phil. Quote
Johnboy GT Posted August 4, 2010 Posted August 4, 2010 I bought scooby sport seats out the yellow 2000 model sport. Cut the feer off my starlet seat rails, welded them to flat bars and then welded the flat bars to the seat. I suppose they are a wee bit high, but im short Quote
