whitetrash Posted August 3, 2010 Posted August 3, 2010 What oil do you guys recommend? Grade/Brand Quote
Liam_D Posted August 3, 2010 Posted August 3, 2010 Ive always used 10w40 Castrol Magnetic but mines only a N/a so it'll be a different grade for yours if its a Turbo. Quote
Dan507 Posted August 3, 2010 Posted August 3, 2010 at work we sell 'motorsport' oil witch is 5w-50w senthetic. this might be worth ago with high powered starlets. Quote
Asad Posted August 3, 2010 Posted August 3, 2010 Autodata recommends 10w30 but 10w40 can also be used for the 4E-FE Quote
ForresGlanza Posted August 4, 2010 Posted August 4, 2010 Use 10w40 magnatec in mine too and seems to work out fine. Thought it would be good as it's supposed to protect from start up. Quote
addz Posted August 4, 2010 Posted August 4, 2010 10w40 semi-synthetic Mobil super sThat's what i'm currently running on a CT9 as a note Quote
