gtmuzz Posted August 11, 2010 Posted August 11, 2010 Was thinking about getting a TD fuel pump for the gt, BUT! What else would I need or is it just fit it and away u go??Basically its in need of more fuel high in the revs as I feel its lacking power so....... This is what ive got so far:Ported mani/wastegate (ct9)gutted catHKS actuator set at .75-ish creeps to .85-ish (wastegate needs some more porting)exhaustFMICfront mounted air filterAny help is much appreciated and I apologise if its been asked before Ta Quote
addz Posted August 11, 2010 Posted August 11, 2010 All you need is the fuel pump, wiring kit, filter pad and away you go.Below is a picture of what's required, but it's basically what you get:) Quote
gtmuzz Posted August 11, 2010 Author Posted August 11, 2010 All you need is the fuel pump, wiring kit, filter pad and away you go.Below is a picture of what's required, but it's basically what you get:)Nice one cheers Quote
gtmuzz Posted August 11, 2010 Author Posted August 11, 2010 One more Q? will it give much benefits? Will it fulfill my needs?? lol Quote
Steve GT Posted August 11, 2010 Posted August 11, 2010 Yes the TD fuel pumps are more than capable of fueling any ct9 set-up wether your running 0.6 bar or 1.2 bareverything required to fit it you get in the kit Quote
rorenapier Posted August 11, 2010 Posted August 11, 2010 More fuel in the high revs???I very much doubt that with the boost presures your running.If anything it will be over fuelling into the 10's AFR (usual on STD setup)Get a wideband on it and see how its running 1st before spending money on something that isnt needed.ALSO remember that the CT9 wont give much above 6k rpm, theres no power there or torque!! Quote
gtmuzz Posted August 11, 2010 Author Posted August 11, 2010 ALSO remember that the CT9 wont give much above 6k rpm, theres no power there or torque!!Yup this is exactly what I feel no power or torque above 6k!! I believed it was the fuel ,dont know why tho lol Quote
addz Posted August 11, 2010 Posted August 11, 2010 If you since ownership haven't replaced your fuel pump, do it!I for a year was driving with stock pump, and after replacing it with a walbo 255lph, it felt much smoother, almost as if it was lacking something prior. Quote
Driver Posted August 11, 2010 Posted August 11, 2010 The TD pumps are based on the walbro 225 which are rated to like 450-500bhp correct me if im wrong ?Ive got a stock pump running on a td04 setup at 1.4 bar and its been fine (so far) so i very much doubt you need to replace it in all honesty. Quote
addz Posted August 11, 2010 Posted August 11, 2010 One can never be too sure if the pump is potent or impotent. Especially when modification has commenced Quote
Driver Posted August 11, 2010 Posted August 11, 2010 One can never be too sure if the pump is potent or impotent. Especially when modification has commencedSee what you meen however ...... i was just pointing out it doesnt necisarily NEED replacing, wouldnt hurt to replace it, allthough wouldnt hurt to leave it either. Quote
addz Posted August 12, 2010 Posted August 12, 2010 See what you meen however ...... i was just pointing out it doesnt necisarily NEED replacing, wouldnt hurt to replace it, allthough wouldnt hurt to leave it either.Certainly, I see where you're coming from. But if boost pressure is being raised, and history of fuel pump is unknown, it is nothing but wiser to change it. Quote
Driver Posted August 12, 2010 Posted August 12, 2010 Certainly, I see where you're coming from. But if boost pressure is being raised, and history of fuel pump is unknown, it is nothing but wiser to change it.No argument, if funds are avaliable to do so then by all meens i agree completely. Its just one of those things i havnt personally got round to changing so im fully aware stock pump will do lol. Same as injectors stock injectors taking 1.4 bar with more to go but it felt fast so didnt want to map any higher and risk breaking stock internalls lol. Quote
addz Posted August 12, 2010 Posted August 12, 2010 No argument, if funds are avaliable to do so then by all meens i agree completely. Its just one of those things i havnt personally got round to changing so im fully aware stock pump will do lol. Same as injectors stock injectors taking 1.4 bar with more to go but it felt fast so didnt want to map any higher and risk breaking stock internalls lol. Quote
