I need a new clutch and was thinking whether i could put a 5efhe clutch on a 4efe.
Does anyone know if the 5e has a stronger clamping pressure?
If it is the same can someone recommend a heavy duty clutch kit?
with a 5e clutch youd need a 5e flywheel that has a different bolt pattern to the 4e one, so youd have to have the flywheel re-drilled. you wouldnt need an uprated clutch with a -fe unless you were planning on turbo'ing it tho.. but if you really want an uprated clutch tho, buy a 4efte flywheel and an uprated 4efte clutch, and fit them <_<
  • 4 weeks later...
with a 5e clutch youd need a 5e flywheel that has a different bolt pattern to the 4e one, so youd have to have the flywheel re-drilled. you wouldnt need an uprated clutch with a -fe unless you were planning on turbo'ing it tho.. but if you really want an uprated clutch tho, buy a 4efte flywheel and an uprated 4efte clutch, and fit them :D
Got to agree, with 73bhp as standard, there is no need for an uprated clutch
Temptation is there but there are better places to spend the money :p
  • 1 month later...
