Rossi ep91 Posted August 14, 2010 Posted August 14, 2010 hey guys!is there any other short shifter on the market apart from the TRD one?is so anyone know where i can get one or a TRD one? i need to shorten up my gear changes Quote
siren676 Posted August 14, 2010 Posted August 14, 2010 There is a diy guide on ep91.com Click here. You may have to register to see it. I am planning to try this but i will try find an extra shifter to practice on. hey guys! is there any other short shifter on the market apart from the TRD one? is so anyone know where i can get one or a TRD one? i need to shorten up my gear changes Quote
01sik Posted August 16, 2010 Posted August 16, 2010 C's short shifter, they are better than the trd one Quote
redz11 Posted August 16, 2010 Posted August 16, 2010 C's short shifter, they are better than the trd one more details on this "C's" short shifter please Quote
enzo_e492901 Posted August 18, 2010 Posted August 18, 2010 Diy is the way to go with short shifters. When I disassembled mine to mod it I measured between the centres of the pivots/balls on both the centre sitck and side leaver and noticed they were exactly the same length. I did some research and found other toyota cars where the modders had lengthened both parts to the same length to not only give a shorter throw but to make the gears a little closer together.To move the ball 10mm on the shaft use the EP91 guide but to make the side lever 10mm longer I recommend cutting out a 5mm piece and welding a 15mm piece in its place. The plastic housing needs a section cutting out and you need 4 10mm spacers under it when installed back in to the car.This is installed in my car and I can select all gears with no problems but I have not driven it yet.As I said above diy is the way to go because it costs nothing if you can machine your own spacers and about £10-£15 if not.Gavin Quote
micky boy Posted August 18, 2010 Posted August 18, 2010 Thanks for puting that up Gavin, i've been wondering how people have been moding there OEM shifters now i know cheers Quote
enzo_e492901 Posted August 18, 2010 Posted August 18, 2010 Not a problem mate. I like sharing my knowledge thats what this club is all about. Quote
ragz Posted August 18, 2010 Posted August 18, 2010 more details on this "C's" short shifter please im also selling a C's quikshift pm me the throw is much shorter with the C's unit trd one felt same as the oem unit Quote
micky boy Posted August 18, 2010 Posted August 18, 2010 Not a problem mate. I like sharing my knowledge thats what this club is all about. Quote
Rossi ep91 Posted August 22, 2010 Author Posted August 22, 2010 im selling one mate.you selling a C's or TRD one matt? and how much pm Quote
Rossi ep91 Posted August 22, 2010 Author Posted August 22, 2010 90 delivered if you want my C's short shiftgot any pics mate ?pm me some prices on other parts you selling may be interested in your wheels Quote
