Amjad Posted August 30, 2010 Posted August 30, 2010 Hey Guys,I will be taking off my Manifold and Turbo off soon and wanted to know where is the best/cheapest place to get hold of a new set of gaskets?Or would it be okay using a Gasket Sealant?Thanks,Amjad Quote
ryan lang Posted August 30, 2010 Posted August 30, 2010 if your careful enough mate you should be able to use them again Quote
Steve GT Posted August 30, 2010 Posted August 30, 2010 cheap in this case is true fail. if you ever buy a new zorst etc they send you gaskets down and they truly are crap il tell you i know socks and loads of others have had the same problemdeffo genuine toyota matey for these i wouldnt get them from anyone else Quote
Amjad Posted August 30, 2010 Author Posted August 30, 2010 Cheers Steve, better safe than sorry eh! Quote
Steve GT Posted August 30, 2010 Posted August 30, 2010 yeah deffo mate aftermarket gaskets blow in no time deffo toyota they will hold Quote
ro55ifumi Posted August 30, 2010 Posted August 30, 2010 Definately genuine from your local toyota dealer an i'm speaking from experience of fitting cheap then having to pull it all apart again after the mani let go on all 4 cylindersJohn Quote
Amjad Posted August 30, 2010 Author Posted August 30, 2010 Any idea how much they are?I'm taking my Mani off for porting, should I need to replace my turbo to mani/turbo to cat gaskets too? Quote
ro55ifumi Posted August 30, 2010 Posted August 30, 2010 Mani roughly £17 an only if you split the units, so yes to the mani,turbo an again about £17 for that on too Quote
Amjad Posted August 30, 2010 Author Posted August 30, 2010 Cool! A lot cheaper than I thought it'd be, thanks for that! I've seen Turbo/mani Turbo/cat ones for 50 Euros on here! :SAny idea on how much the Turbo/Cat one is? As I wanna gut the cat too while I'm at it lol Quote
Matt Glanza Posted August 30, 2010 Posted August 30, 2010 Turbo to cat ones are about twenty odd quid maybe a bit more.u will need new bolts aswell because they are one time use nuts Quote
Amjad Posted August 30, 2010 Author Posted August 30, 2010 Thanks Matt! I'm having a nightmate getting the mani bolts off guys, tey won't budge! Any tips? Quote
ro55ifumi Posted August 30, 2010 Posted August 30, 2010 Impact driver, or a bar!!! they will be tight as it's prob first time they have been off just persevere an spray with some wd40 Quote
addz Posted August 30, 2010 Posted August 30, 2010 I had driven my car down to my mates garage before attempting to remove mani bolts, I guess they were quite warm, hence why they weren't such a pain?Start her up letting her warm up a touch, I then guess WD40 it if you haven't already done so.Gaskets from Toyota all the way - pay the little extra for better quality Quote
CLARKYTRD Posted August 30, 2010 Posted August 30, 2010 have all gaskets u need if u want themmake me an offer! Quote
Amjad Posted August 30, 2010 Author Posted August 30, 2010 Addz that definitely sounds like it just needs to be heated up then! My ratchet was useless, when it's running I may just take it down to a garage to get the bolts loosened off, don't wanna risk snapping them!Heat shield was a joke though, one of the bolts has rounded off so I have a mangled (after trying to rip it off) heat shield that needs to be cut off now Quote
