Hey Guys,
I will be taking off my Manifold and Turbo off soon and wanted to know where is the best/cheapest place to get hold of a new set of gaskets?
Or would it be okay using a Gasket Sealant?
Thanks,
Amjad
cheap in this case is true fail. if you ever buy a new zorst etc they send you gaskets down and they truly are crap il tell you i know socks and loads of others have had the same problem
deffo genuine toyota matey for these i wouldnt get them from anyone else
Definately genuine from your local toyota dealer an i'm speaking from experience of fitting cheap then having to pull it all apart again after the mani let go on all 4 cylinders
John
Any idea how much they are?
I'm taking my Mani off for porting, should I need to replace my turbo to mani/turbo to cat gaskets too?
Cool! A lot cheaper than I thought it'd be, thanks for that! :(
I've seen Turbo/mani Turbo/cat ones for 50 Euros on here! :S
Any idea on how much the Turbo/Cat one is? As I wanna gut the cat too while I'm at it lol
I had driven my car down to my mates garage before attempting to remove mani bolts, I guess they were quite warm, hence why they weren't such a pain?
Start her up letting her warm up a touch, I then guess WD40 it if you haven't already done so.
Gaskets from Toyota all the way - pay the little extra for better quality
Addz that definitely sounds like it just needs to be heated up then! My ratchet was useless, when it's running I may just take it down to a garage to get the bolts loosened off, don't wanna risk snapping them!
Heat shield was a joke though, one of the bolts has rounded off so I have a mangled (after trying to rip it off) heat shield that needs to be cut off now :(
